1. hazzstagram's Avatar
    Two days ago, I charged my Infuse and went back to unplug it after two hours, I turned it on but I couldn't. I used the volume + power button combo and later it turned on and worked perfectly fine.
    Today, I was charging it and I went to unplug it; but now it doesn't want to turn on or charge at all. I tried the volume/power button combo again, but this time it did not work! I'm getting really worried and frustrated!
    I connected it to my laptop/PC and for a few minutes, I saw the battery icon, and then it went away, I waited but nothing happened! I plugged it onto the wall with my charger and it didn't work. It still doesn't want to turn on either.
    Sorry, if it's a little long..Please help!
    12-07-2012 02:16 AM
  2. DroidXcon's Avatar
    Sounds like your battery is going. Are you using the same cable in all these situations. Could be cable isn't charging. Your phone. Do you have insurance on the phone ?
    From my Galaxy Note 2 via Tapatalk
    12-07-2012 02:53 AM
  3. hazzstagram's Avatar
    Yes, I do use the same cable all the time, could my battery be the problem or the charger that I'm using? No, I don't have insurance.
    12-07-2012 11:05 PM
  4. DroidXcon's Avatar
    Yeah Try a different cable
    12-08-2012 01:14 AM
  1. Atrix won't turn on or charge
    By eviljiggy in forum AT&T ATRIX
    Last Post: 09-29-2016, 07:19 PM
  2. Droid 2- won't turn on or charge- help?
    By CourtneyParke in forum General Help and How To
    Last Post: 02-27-2013, 08:00 PM
  3. Thunderbolt won't turn on or charge... help!
    By ninetales in forum Verizon HTC Thunderbolt
    Last Post: 09-30-2012, 08:25 AM
  4. Got my $600 Xoom and I want to have sex with it.
    By Cretz in forum Motorola Xoom
    Last Post: 03-05-2011, 07:10 AM
  5. What would cause my screen to turn on periodically?
    By dburr in forum Samsung Moment
    Last Post: 12-03-2009, 05:04 AM
