Results 1 to 5 of 5
- 06-13-2011, 08:12 AM
Thread Author #1
The button/icon click noise?
I don't know how to properly describe this: the "click" noise or tone that goes off when you click any icons or buttons... All I know is when volume is off (muted) that click noise is also muted, but at any volume level the click noise is always at full volume. Like that click tone is just either on or off (and very loud). I can't find anything in the settings related to it.
Is there a way to control the volume level of this? Thanks!Last edited by Dreven; 06-13-2011 at 08:30 AM.
- 06-13-2011, 08:29 AM #2
Go to settings -> Sound and it should be there under system sound. Don't have the phone in front of me so I can't check.
- 06-13-2011, 08:42 AM
Thread Author #3
- 06-13-2011, 11:02 AM #4
- 06-13-2011, 12:23 PM #5
It's called "audible selection," as posted above. Turn that off, and you're good.
Reply
