eXtreme versions of NINE must have Android tools now come packed in a box!!
Gift your Android nine "Magical Powers" with our 'Toolbox eXtreme', 'Toolbox eXtreme' will prove to be the best thing you would have done for your Android since loving it!
Download Links:
★★ Features ★★
★ eXtreme Network Signal Recover: You will be always connected to your Network, 4G\3G\2G. Your Internet connection will be amazingly faster.
☆ Recover lost network signal in less than 30sec.
☆ 4G over 3G.
☆ Best call quality.
☆ Faster Internet.
☆ All types of technology support: 4G/3G/EDGE/GSM/CDMA
☆ No more dropped calls.
★ eXtreme WiFi Repair: Your WiFi will be stable and repaired every time.
☆ Repairs Small range WiFi issues. (Kind of extending the range)
☆ Stabilizes WiFi, No more fluctuating WiFi.
☆ Repairs IP conflict.
☆ Quick Repair in less than 30sec.
☆ Maintains best WiFi speed available from the router.
★ eXtreme Cleaner: You will always find your memory clean, No more junks and temporary files.
☆ The most amazing cleaner in Android.
☆ Recover 100+ MB of internal memory in just one click.
☆ Cleans All App's cache, cleans several more MB than any other cleaner.
☆ History Cleaner: Browser, Google Play Store, Gmail, Google Maps, Clipboard.
☆ Auto Clean Memory: Automatically clean your Android 'per day', 'per 3 days', per week, or 'biweekly'.
★ eXtreme Task Killer: Your Android will run smooth and faster, Acts as Memory Booster.
☆ Boost your RAM by safe killing tasks.
☆ Kill any tasks that consumes RAM.
☆ Safe kill Services and Process of any Apps without making those App crash.
☆ Kill tasks all together or individually.
☆ White-list Add/Remove. (Apps in white-list won't be killed).
☆ Save battery by killing apps that drains lot of battery.
☆ Uninstall Apps that seems to be suspicious.
☆ See details of tasks before killing.
★ eXtreme Battery Saver: Your battery life gets extended up-to 2 times normal life.
☆ Intelligent Battery saver with 4 saver modes.
☆ 1.2X, 1.6X, 2.0X Battery saver. Extends battery life to 120%, 160% or 200% respectively.
☆ User Defined Battery saver. Create your own customized saver mode.
☆ Auto battery saver: Automatically switch to battery saver mode when battery level falls below 50%,40%,30%, or 20%.
☆ Tested in ICS, Proved to be a very effective Battery Saver you can get in Android Market.
★ eXtreme Memory Info: Know your Memory
☆ Get All 'must know' info of your Android Memory.
★ eXtreme Battery Info: Know your Battery
☆ Get All 'must know' info of your Android Battery.
☆ Dynamic info: All the details are updated instantly for any changes.
★ eXtreme Network Info: Know your Network and SIM
☆ Get All 'must know' info of your Network & WiFi & SIM & Data connection.
Portions of this page are modifications based on work created and shared by the Android Open Source Project
and used according to terms described in the Creative Commons 2.5 Attribution License. AndroidCentral is an independent site
that is not affiliated with or endorsed by Google.
