G Tablet: Need Some Tips
In HC, there is a soft button that does the same thing as holding the home button. Press it and you will see screens of the latest applications that are open.
I left wifi on while setting it up which I had no problems. I did a wipe of everything before I installed. Yes, I do miss Tweetdeck but I will live with plume until then.
Remember, its an beta so we will have to wait till it get better hopefully.
First install I had multiple reboots. I reinstalled & did a data wipe & factory reset. It doesn't crash as much but it still does quite a bit.
I can't get rid of the wifi error & app installs from the android market won't dl or go away from the notification bar. Amazon app works for dl tho.
Does BOS 2.4 works better? I like honeycomb but so far with the reboots & wifi error the latest version si pretty unusable at least for me.
do you all use a screen protector? if so which?
jipeve
