Does anyone with a Thunderbolt use the Torque automotive performance monitoring and diagnostic tool?
Which ODB2 Bluetooth adapter are you using, and how is the functionality?
I've heard that the cheaper adapters are less reliable, and the ones that plug in without a cable can stick out too far and can hit your leg while your entering/exiting, or driving.
I have a Saturn SC2 (sport coupe 2), and am thinking of getting a Kiwi adapter to use with Torque. The price is a little higher, but it's supposedly reliable and has a long cord, so that the adapter isn't jutting straight down.
The app recommends Scantool, OBDKey, Kiwi, or ELM adapters.
