The wall charger that comes with the cheap Chineese knock-off batteries is the smallest I've seen. You can typically order one by itself for around $5+ on eBay, or around $15 with two cheapy batteries. I've heard reports of these chargers sometimes not working but I think they usually do. I have one, and it works well enough, but it does not charge the battery as fully as the larger Seidio charger or when charging the battery in the phone. The protective circuitry turns off the charging somewhat sooner. I don't know if this is a common trait or just individual variability among units.
