Case to fit Extended Battery
byrds8
717
12
Any suggestions on a case/clip that will fit over the extended battery? I have a hard shell on the phone now but with the extended battery it wont fit in my old pouch.
LAKingsDru
72
I just bought from the Verizon store by my place, it's a hard shell case but also it fits into a holster. I will try to find a pic.
Sent from my ADR6400L using Tapatalk
fresefrog
7
Trident case (tridentcase.com) just released the Electra case which comes with an integrated screen protector, holster, and extended battery. It is listed for $69.95 but when I added it to the cart it came up for $64.95. If your not in a hurry they also are offering standard shipping for free.
Bond32
1,358
35
The shell/holster combo from Verizon is sweet! Just picked it up, light on bulk, good protection.
Brainfart
161
6
Siedio all the way. They have a couple hard cases that will fit the extended battery and have a clip available also. I have had Siedio cases for the last 3 phones and will never get anything else. They are worth every penny. I have the Convert and love it.
Bond32
1,358
35
I used to feel the same. But the shell holster combo is basically the same case as the seidio surface and you get a holster for much cheaper.
tallen316
Active member
Feb 9, 2011
36
I picked up a seidio active nib on the bay for a total of $23 which included shipping. It's the best price I could find anywhere.
Sent from my HTC Tbolt using Tapatalk
Jude526
Trusted Member
Dec 13, 2010
3,936
109
There is a slip on case from Verizon not a full leather case though. It is a deep maroon color....only color they have. But it is at least a choice !
defcon999
823
82
Are you talking about the one that is black and "rubbery" feeling with the text sqaure pattern?
I have that one too...I like it alot, just make sure that you don't break the clip off (like I did) getting into your car.....I had to drop another $24 to get a new one....even though everything was good. Wish they would make the clip like the other ones where you can just slip it on and off!...other than that....great case/shell/holster combo!
