1. TMusil14's Avatar
    I just got my HTC Thunderbolt replaced because the screen broke and the Bluetooth no longer automatically connects with my car (2012 Subaru Impreza). Prior to my screen breaking, my phone would connect to my car just by turning the Bluetooth on. My new HTC Thunderbolt says its paired with my car, but will not automatically connect. I have to monkey around with the Bluetooth settings on my phone before it connects. When it is connected it often disconnects after a couple minutes. While this may seem like an easy fix, it is dangerous to mess around with the settings while driving. Does anybody else have any problems with this? Got a fix?
    Sent from my ADR6400L using Android Central Forums
    10-04-2012 08:29 AM
  2. ArloSoft's Avatar
    Hi,
    You may like to take a look at MacroDroid on Google Play. You can setup a trigger when bluetooth is turned on and add an action to connect to your car's audio.
    https://play.google.com/store/apps/d...crodroid&hl=en
    If you want any more information or help then let me know.
    Cheers,
    Jamie
    TMusil14 likes this.
    10-09-2012 05:03 AM
  3. TMusil14's Avatar
    Thanks bro. I the phone they sent me is broken though.
    11-13-2012 06:38 AM
  4. Ocone's Avatar
    This maybe well known but HTC bluetooth will auto connect. All I did was re-pair the phone using the car's steering wheel voice controls. Also, if you elect the phone's "Car" icon, that interface will also cause auto connect.
    12-03-2012 06:22 PM
  1. Bluetooth Initial Connection Issue
    By chuckawd in forum Verizon HTC Thunderbolt
    Last Post: 02-19-2012, 11:26 PM
  2. Bluetooth auto connection
    By jbcjeyes in forum General Help and How To
    Last Post: 01-13-2012, 11:45 AM
  3. Bluetooth Connection Issues
    By jneusch in forum Verizon LG Revolution
    Last Post: 10-26-2011, 10:41 AM
  4. BLUETOOTH not auto connecting in car!!
    By worldcreator in forum LG Optimus S
    Last Post: 05-02-2011, 09:33 PM
  5. Bluetooth connectivity issues
    By Flashdancer11 in forum General Help and How To
    Last Post: 11-30-2010, 12:57 AM
