hi, can anone point me in a direction go get a hardshell or gel case for my thunderbolt with the extended battert? Not looking for a pouch, but a gel /protective case
Check out HTC ThunderBolt Extended Battery Silicone Cases. Kind of pricey at $25, but it seems to be the only case available for the extended battery.hi, can anone point me in a direction go get a hardshell or gel case for my thunderbolt with the extended battert? Not looking for a pouch, but a gel /protective case
Or you might try making one yourself by buying the regular gel case for half as much and using an X-acto knife to make the cutout for the battery and stand.
OK, Seidio finally has a picture of the Rugged case for the Extended Battery even tho it still says Coming Soon we can least see there is a design and hopefully means they are going to be available soon.
CHECK IT OUT.
Check out the reviews on those cases, looks like they cover the front camera and it's a hack job. Someone takes a knife to a standard battery case.
CHECK IT OUT.
These new cases cover the TB kickstand so you'll have to use the kickstand that's on the case, and who knows if they will be long/strong enough to hold up the phone vertically....
