Results 1 to 5 of 5
Like Tree3Likes
  • 1 Post By SoDev
  • 2 Post By Smitty_82
    jbeastafer's Avatar
    Posts
    ROM
    | InfectedROM Eternity
    Default Need a bit of help.
    Trying to do my homework before i flash Liquid thunderbread 2.3. Do i need to upgrade the kernal first or after i install the rom? Is the kernal baked into the download file on the xda website? Sorry for the noob questions just want to make sure before i wreck my new phone Thanks.
  2. #2
    SoDev's Avatar
    Posts
    Global Posts
    1,035 Global Posts
    ROM
    CM7 RC1.2
    Default Re: Need a bit of help.
    It's good to ask man.
    It will come with a kernel built in. You can change it later, but you need the rom first and you don't need to change it at all.
    -SoDev
    fatboy97 likes this.
  3. #3
    Smitty_82's Avatar
    Android Addict
    Posts
    Global Posts
    1,590 Global Posts
    ROM
    ICS / Stock
    Default
    I would check to see how you like to kernel that is with the ROM first. Then go from there.
    fatboy97 and SoDev like this.
  4. #4
    Both SoDev and Smitty_82 are correct... I flashed the ROM a while ago and have been using with v2.2 and now v2.3... the kernel can be replaced, but as you might have seen on the thread I started with v2.2 the ROM is great on battery life as is... I've continued posting information on the v2.3 on the thread just because I can not change the title.
    Samsung Galaxy S4
    Droid Razr Maxx, HTC Thunderbolt, HTC myTouch 4G (Retired)
    Blackberry's 8900 to Bold (Retired)
    Flames Wallpaper
    Jerry: "Love, Peace, and Chicken Grease!!!"
  5. #5
    Fat_Rabbit's Avatar
    Posts
    ROM
    CM7
    When I was running thunderbread the kernel that came with it did the trick for me
