Hey all, my 'Bolt battery drained all the way down and my device powered down. I waited til I got home to plug in, let it charge for a few minutes and then booted back up while still plugged in. I now have this error message on my screen: "UIDs on the system are inconsistent, you need to wipe your data partition or your device will be unstable." I my only option to leave this error message is a button that says "I'm feeling lucky." I tried this and was bombarded with constant force close errors from various applications. I'm guessing my solution is to boot into recovery and wipe data partition from there then reboot but I want to make sure nothing will be ruined in this process. I've never seen this error before so bear with me. I would like to note that I haven't made a nandroid backup with this latest setup (1.8.6 with the S squared blue theme) yet. Am I screwed?
Thanks in advance :'(
