DEAL OF THE DAY: Save 60% on the LLOYD Flex Case for LG Nexus 4!
Results 1 to 3 of 3
    Default ok need help with my messed up phone
    ok I need help. Today I tried to flash Bamf pr 3 up from the pr 2 I had before. Everything worked great except for when I set up the Rosie. Then I lost wifi and couldn't get it back. That was a deal breaker so I went into ROM manager and tried to flash back my previous ROM. Then my phone got stuck at the HTC Screen. So after a half hour I bit the bullet and did a battery pull. Then figured I'd boot into recovery and flash manually. But when I do I get the Hboot trying to update my radio. The only thing is I already have the latest radio. Is it trying to update an older radio. That's why I'm scared to take the update. I can't remember what the latest radio number is. Anyway when I hit cancel it won't give me the option to go into recovery.
  2. #2
    Default Re: ok need help with my messed up phone
    Looks like sdcard contains PG05IMG that has the radio update. If you have a PC or secondary smartphone besides your Thunderbolt, I would insert the sdcard and delete that PG05IMG file. After this, hboot should not try to load anything and you can select and enter into recovery mode.
    Quote Originally Posted by msk522 View Post
    You know thats a good idea. I'm gonna try that thanks
