[RADIO] [TB] 1.48.00.0817r (CDMA) + 0.01.78.0802w_3 (LTE)
Upstreammiami
2,098
482
Huge thanks to barcodelinux over at rootz
Here are the radios from the 2.11.605.0 leak today.
The versions are:
CDMA: 1.48.00.0817r
LTE: 0.01.78.0802w_3
Multiupload.com - upload your files to multiple file hosting sites!
md5sum: 4fcb0fe75b891e9d706822c175d049af
As usual, make sure it's named PG05IMG.zip, flash through HBOOT, and hope for the best. Don't blame me for anything that goes wrong with your device.
This is the radio I been waiting for... I went from a fluctuating 2-3 bars of signals at job to 5.. I say this does good by me so far was Uber BAMF V3.
Cool, i've been happy with the new radio that is a week or so old, I'm going to give this one a ride today and see what I get out of it.
So I think I'm going to flash this today, anyone have any complains with the newest radio on Gingeritis VII?
is it a problem to reflash the same LTE radio or should i just flash the CDMA radio. Will it cause any problems to flash both even though i already have the most up-to-date LTE radio? I read somewhere that reflashing the same radio can brick your phone. Is this true or not? Thank You!
Reactions: wilsoda
I did it today. No problems here.
Reactions: gdoggmil04#AC
Do I have to wipe my phone before updating just this CDMA radio or can I just update the radio in the bootloader without wiping everything?
No you should be able to update radio without wiping system.
I still have the official OTA mr2 radio on my phone, and i havent flashed any of the new ones yet... im just a little confused, do i have to flash just one of the radios? or do i have to flash the cdma and the lte radios each? and is it worth it?
OK...so this is different then from when I installed the ROM? I am new to this...sorry!
Is this radio compatible with the gingeritis viii rom that was just release? Sorry noob
I'm using the newest radio with this and I keep dropping to 1x?
Sent from my ADR6400L using Tapatalk
No just one dont have multiple radios in your sdcard
Tfalbaga
