Results 1 to 7 of 7
Like Tree1Likes
  • 1 Post By wildman
    XStroX's Avatar
    Posts
    Global Posts
    111 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Camera won't work - Gingeritis VIII
    I finally rooted using revolutionary method and then installed Gingeritis VIII. So far I am loving it but I can't get the camera or camcorder to open. I click the App and they look like they're going to open but then it closes before I ever see anything through the viewfinder.
    Any ideas?
  2. #2
    wildman's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Camera won't work - Gingeritis VIII
    Comineeyeaha likes this.
  3. #3
    fatboy97's Avatar
    Posts
    Global Posts
    13,486 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Did you do a Factory Data Wipe, Wipe Cache and Wipe Dalvik cache before installing the ROM.... also did you check the MD5 Sum code of the ROM before you installed it???
    XStroX's Avatar
    Posts
    Global Posts
    111 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    This worked! And I found the permanent fix in the same thread. Thanks!
    XStroX's Avatar
    Posts
    Global Posts
    111 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by fatboy97 View Post
    I did all three wipes before installing the Rom. I did not do anything with the MD5 sum code though as I never saw any directions related to that in the two tutorials I followed.
  6. #6
    whodatkiid's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Camera won't work for me after revolutionary method with first GB leak. Need help!? Goes black then back to home screen.
  7. #7
    wildman's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by whodatkiid View Post
    Solution link is on 2nd post..
