Results 1 to 6 of 6
- 09-20-2011, 10:33 AM
Thread Author #1
HELP with Roms, radios, etc..PLEASE
So ive installed a couple of different roms but had major problems, as far as camera not working.. no mobile network, etc.. what is a reliable and stable but still pretty cool ROM for my thunderbolt.?? ive been searching through forums but cant really find anything good..any help is appreciated
- 09-20-2011, 11:16 AM #2
- 09-20-2011, 11:43 AM #3
- 09-20-2011, 12:04 PM #4
Re: HELP with Roms, radios, etc..PLEASE
Well no...the stock ROM is froyo...the only thing I know that doesn't work in forever is the mobile network widget. The guys that make froyo roms have a release version to base their work off of, but i've never used a froyo based custom ROM so I couldn't give you much help in that area. You could always go stock rooted.
- 09-20-2011, 12:08 PM #5
I guess what I should have said is my stock Froyo is stable and everything on it works as it should.
If I were to replace the stock rom with Bamf Forever, would all features of the phone still work (4G, camera, GPS lock, etc etc) as if it was a the stock Froyo.
Cause I like how the phone works and I don't want to give up *any* features.
If the *only* thing that doesn't work is the network widget, I'm fine with that. - 09-20-2011, 12:36 PM #6
If your mobile network isn't working I'm assuming you flashed a GB rom without updating your radio. Take a look in the Hacks section (smae place I'm moving this thread to) there are a few thread with the different radio's for GB. Also there is a thread that has the camera update if your is not working sorry I don't have time to post links but if you have trouble finding them just let me know and later I'll get you the links.
Steve Bamf roms work as good if not better then the stock Froyo your running. I don't have any issues with any application or feature of my phone since I don't use the network widget.
Reply
