Results 1 to 9 of 9
    Bobman's Avatar
    Posts
    Global Posts
    209 Global Posts
    Default G+ Hangout not recognizing front facing camera on CM7
    I updated my Google+ app yesterday to try out the new features. Specifically, I wanted to try the Hangout feature from my phone. But it says it requires a front facing camera (which I obviously have). Is this a result from me running a custom ROM (CM7 RC1.7)?
    Has anyone else had this issue on other ROMS? Here is a screenshot I put on Google+ yesterday.
  2. #2
    opjones's Avatar
    Posts
    ROM
    Pure Google/CM7
    Default Re: G+ Hangout not recognizing front facing camera on CM7
    I wanted to try this last night to see how it worked on cm7, bummer if this is the case.
  3. #3
    aldenoneil's Avatar
    Posts
    Global Posts
    6 Global Posts
    Yep. I even have the MIUI cam on CM7, which does recognize the front camera, but still no dice on Google+.
    Bobman's Avatar
    Posts
    Global Posts
    209 Global Posts
    Quote Originally Posted by aldenoneil View Post
    Yeah, my front camera works great in my camera app and even Skype. Just no luck with G+. Maybe it is an issue that Google can fix with an update instead of requiring a CM7 update.
  5. #5
    Same issue here
  6. #6
    Here you go guys
  7. #7
    One Radical Dude's Avatar
    Posts
    ROM
    Team BAMF, ICS 4.0.3
    With the latest version of CM 7, it appears that I was given the option now to join a hangout. I didn't do any tweaks or anything.
  8. #8
    I'm not rooted and don't wish to do so. Is there a way to accomplish this for us amateurs?
  9. #9
    mrtonk's Avatar
    Posts
    Global Posts
    476 Global Posts
    Quote Originally Posted by Doubledad View Post
    If you aren't rooted, the front camera and Hangouts should work just fine.
    Sent from my unSensed ICS Thunderbolt with Tapatalk 2
    "I went back to Sense when I realized how much work I was putting into making AOSP look like Sense."
