Results 1 to 10 of 10
- 10-07-2011, 03:09 PM
Thread Author #1
aosp data speed issue
hi i rooted my thunderbolt a couple of days back and put on a aosp rom mini bamf 1.0. the only problem ive been having is my data speeds have plumented i have 4g where i am at. and before i was rooted i was getting 10-15mbps now im ony getting 2-3 not good. has any one else running this rom and getting good speeds. i also have the same problem on cm7. thanks for all the help
- 10-14-2011, 07:59 PM #2
Re: aosp data speed issue
I'm having the same issue after loading bamf saob 1.01. before I was on bamf forever 1.0.7 and when I did a speed test, it upoaded over 14mb and shows it was on LTE network but now when in a 4g area, the test only get about 2mb and, even though the thunderbolt is showing its on 4g, the results are showing that it only testing on a 1xRTT network
- 10-14-2011, 08:55 PM #3
I just download SpeedTest and did a few tests... all between 9-11, but I just got a 15 down... and that is with CM7... it's not an AOSP ROM issue.
Droid Razr Maxx
HTC Thunderbolt (Retired)
HTC myTouch 4G (Retired)
Blackberry's 8900 to Bold (Retired)Flames Wallpaper
Jerry: "Love, Peace, and Chicken Grease!!!" - 10-15-2011, 08:18 AM #4
Could it be that I need to update my radio? I didn't change the radio at all. I just got the thunderbolt as a replacement a week ago and I'm using whatever the radio set up is that came with it. Possibly MR2
- 10-15-2011, 09:24 AM #5Droid Razr Maxx
Jerry: "Love, Peace, and Chicken Grease!!!" - 10-15-2011, 10:41 AM #6
Sorry, I was thinking that I should have included the baseband numbers after I sent that message. My numbers are 1.39.00.0627r, 0.01.69.0625. Again, the phone is definitely switching/showing a 4g signal when I enter from a 3g area into a 4g but it doesn't seem to be connecting to 4g internally or sending/receiving at 4g speeds.
- 10-15-2011, 10:50 AM #7
1.39.00.0627r, 0.01.69.0625 is one of the last Froyo based radio files. I'm using one of the last Gingerbread radio 1.48.00.0906, 0.01.78.0906, which was based on the last OTA Gingerbread release... if you flash these files from the link in my signature you will need to flash both the CDMA radio and the LTE radio separately. I have had no issues leaving my 4G area and going north, or returning to my 4G area... it's probably worth trying if you are having issues with the older radio files you are currently using.
Droid Razr Maxx
Jerry: "Love, Peace, and Chicken Grease!!!" - 10-15-2011, 11:40 AM #8
- 10-15-2011, 11:57 AM #9Droid Razr Maxx
Jerry: "Love, Peace, and Chicken Grease!!!" - 10-15-2011, 12:01 PM #10
ah ha, now I get it. This is the one thing that has been confusing me and holding me back the whole time from installing a new radio. I couldn't understand how I could install two files of the same name at the same time. Awesome! Thank you again!!!
Reply
