I had to get a replacement Thunderbolt for a speaker issue.
Made a backup of my TB with Rom Manager, which has always worked for me.
Put SD card in new TB.
I rooted the new one with Revolutionary.
Flashed Superuser.
In CWM, I decided to go directly to restore.
Checking MD5 sums took longer than usual. Said erasing boot before restore, then restoring boot image. THEN....it says the following:
system.img not found. Skipping restore of /data.
data.img not found. Skipping restore of /data.
.android_secure.img not found. Skipping restore of /sdcard/.android_secure.
cache.img not found. Skipping restore of /cache.
sd-ext.img not found. Skipping restore of /sd-ext.
Restore complete!
And of course, there is only the stock ROM when I reboot.
Signed in, etc.
Downloaded ROM Manager & Premium from the Market.
Fired up ROM Manager, went to restore. Same thing, except it only appears quickly and then reboots.
I think to myself - perhaps it wasn't updated to the new radio and I should have installed the update. So I find a debloated stock 2.11.605.5, install it with CWM, and still...no go.
Is there a step I am missing, or should I give up on this backup file?
Flashed Superuser.
Restore complete!
Signed in, etc.
