been running liquid smooth since early december and all was good until last weekend. went out of town for easter to a place that doesnt have 4g so i turned it off and then almost immediately started having problems like apps freezing and having to pull the battery pretty often.... so i got back home and turned on 4g and thats when the problems really started, first some apps wouldnt open, then i wasnt able to download ANYTHING outside of an app in the market/play store, and then the final straw was when my phone no longer recognized my sd card... so i restored using an old nandroid from about a month and half before and it helped a little but still wasnt back to normal. so i decided to try another rom and first tried eternity and was stuck in a forced close loop of hell, so i restored again. phone was almost back to normal but decided to try another one. loaded in thunderstick and was stuck with the same thing. now im back with liquid smooth and was wondering if this problem (s) are anything that i cause or if anyone else has encountered them.... also i should not that im running the imosayin lean kernel and was sure to wipe both the cache and the dalvik befure flashing the new rom ..... sorry for the lengthy post but just wanted to make sure i didnt leave out anything that might matter
