Results 1 to 2 of 2
    Wildside's Avatar
    Posts
    Carrier
    BAMF Forever 1.10
    Default Tasker not working with Skyraider
    I recently switched from BAMF Forever 1.11 to Skyraider Zeus 1.3 because I could not resolve the lag that developed when placing calls.
    I'm finding that several of my Tasker profiles either won't fire, partially fire or fire but then return to the previous settings. Many of my profiles work fine though.
    For example, I have a profile that if I'm in a particular location (Wifi near) and have a specific calendar entry the phone switches to silent mode. Then, when the calendar entry clears or if I leave the location, the phone goes back to normal mode. Today the profile fired but while still there and with the calendar entry active my phone started ringing.
    There are other examples; in car dock profile usually doesn't fire, arriving at my office (Wifi near) should kill the home profile if still active, etc.
    I didn't have these issues with any previous ROM I've used (several different BAMFs, CM7).
    Tasker is checked under Accessibility settings.
    Has anyone seen these issues or have any thoughts on resolving them?
    Steve
  2. #2
    Default
    I recommend posting in the bamf forums. You will get more support there.
    Sent from my SCH-i515 Toro
