DEAL OF THE DAY: Save 43% on the Seidio SURFACE Case (with kickstand) for HTC One!
Results 1 to 4 of 4
    jlgraham's Avatar
    Posts
    Global Posts
    98 Global Posts
    Default Thunderbolt power cycling after OTA
    So many of you original Thunderbolt owners may remember the problems many users had with power cycling when the device was first released, VZW and HTC pushed out an update (after months of complaints) which fixed the issue.
    Now after this latest OTA, my Thunderbolt is turning itself off. Not often, Ive only noticed it once every other day or so. I will pull the device from my pocket and press the power button to activate the screen, only to find that the phone is off and the red LED indicator is solid. If I hold down the power button my phone will turn on with no problems, until the power issue happens again.
    I'm using a stock, never rooted TB in a 4G area, Android 2.3.4 (2.11.605.19 710RD).
    Anyone else noticing this issue?
  2. #2
    durbancic's Avatar
    Posts
    Global Posts
    14 Global Posts
    Default Re: Thunderbolt power cycling after OTA
    I don't have this issue, but ever since the update my phone will go into a white screen (htc) and then to a black screen boot loop for anywhere from 5 minutes to 5 hours when I UNPLUG it from a usb or charger. I have a stock, non-rooted phone and I am wondering if rooting will fix this.
    Dan
    jlgraham's Avatar
    Posts
    Global Posts
    98 Global Posts
    I would not recommend rooting to solve a problem like that...probably better to try a factory reset first.
  4. #4
    trter10-imore's Avatar
    ThunderboltTool Developer
    Posts
    ROM
    Liquid JB v2.1 Alpha6
    I would flash a ROM honestly.
    Quote Originally Posted by o0cdiddy View Post
    ...we should rename the TB the Menstrualbolt
    If you like something i have done and would like to contribute my nerd fund, you may do so here
