In your opinion, would this be better than the way I calibrated before. I installed BAMF 1.10 this past weekend, and used the battery calibration tool in BAMF tools, is that the same or would this app be better.
Why do you need to calibrate? Is it so the battery last longer or is it to get and accurate reading? I just flashed cm7 and earlier I rebooted my phone with 39% and when it finished rebooting it was at 14%. I also had that problem with the liquid rom so not sure if it's the battery or is it AOSP roms.
