1. HoosierRealtor's Avatar
    "Unclean shutdown, settings not applied"
    Any time I reboot or flash a new rom, I get this message. It takes me to the CPU Settings and I hit apply on boot and says bamf tool kit has been granted super user permissions. I'm running bamf 1.6.3 remix.
    Thanks for the help
    05-11-2011 08:39 AM
  2. djinsydius's Avatar
    I got that error a couple times when I adjusted the setcpu settings in das bamf toolkit & hit "apply on boot". The error only came up when the max was set noticably lower than the stock settings, what are your settings at when you got the error?
    05-11-2011 09:04 AM
  3. SoDev's Avatar
    I got that a lot too. mine was like 930 or 1036 or whatever it is 245.
    Anyway, I'm back to setcpu for now anyway, but not for that reason.
    05-11-2011 10:17 AM
  4. Adrynalyne's Avatar
    Its a safety measure. If you apply the settings and reboot normally, the issue will not come back. Any abnormal restart, from an app or adb, or random reboot, will cause this.
    NotJustAPhone and dajogejr like this.
    05-11-2011 11:27 AM
