Results 1 to 19 of 19
- 05-14-2011, 08:29 PM
Thread Author #1
Please Help ASAP i need help!!!
ok so i was downloading a new rom and when it restarted it just froze on the HTC sign and froze there need help because if i go to verizon store i wont get a new phone because i rooted it need help ASAP!!!
- 05-14-2011, 08:34 PM #2
- 05-14-2011, 08:55 PM
Thread Author #3
have tryed pulling the battery out a thousand times and somehow got into bootloader but for some reason didnt click on recovery and i cnt actually get into the phone it just sits at that white HTC screen. Ive left it on for about 45 min and it still just stays there
- 05-14-2011, 09:52 PM #4
Is the P50IMG file still on your SDCARD?
- 05-14-2011, 10:35 PM #5
Did you confirm that the root took? did you have superuser in your app drawer afterwards?
What do you mean downloading a new rom - do you mean flashing or just downloading?
Did you flash recovery and make a backup? - 05-15-2011, 10:17 AM
Thread Author #6
- 05-15-2011, 10:19 AM
Thread Author #7
- 05-15-2011, 10:30 AM #8
did you make a backup with recovery?
- 05-15-2011, 10:43 AM
Thread Author #9
- 05-15-2011, 05:31 PM #10
If you can boot into recovery(Power + Volume Down I believe), try restoring your backup.
If you can't get into recovery, bring the phone back; I don't believe Verizon has the ability to boot into recovery if you can't. While I don't advocate doing this, it may be a last resort...Last edited by sirlancelot323; 05-15-2011 at 05:32 PM. Reason: Removed quote.
Motorola Droid RAZR HD - stock (for now
Previous owner of an OG Droid(Sapphire 1.0.2) and a Thunderbolt(Skyraider ZEUS 1.3). - 05-15-2011, 05:40 PM #11
like sirlancelelot said you should, with power off, boot up into bootloader screen (vol down plus power button) and go to recovery with volume keys - press power to select - phone reboots into recovery mode - navigate to back up and restore with volume keys, select with home key, then go to restore > and find your nandroid backup that you made.
- 05-16-2011, 03:56 PM
Thread Author #12
- 05-16-2011, 04:16 PM #13
Something sounds off. This seems like a minor glitch. You should be able to flash the PG file in recovery and fix it. Why don't you explain in detail what's happening.
Follow me on Twitter: @SpaceHippieSays - 05-16-2011, 05:47 PM
Thread Author #14
- 05-16-2011, 07:34 PM
Thread Author #15
ok so i finally got bak into the phone w/ all my apps still in tack then i went to go ondo the rom i originally flashed because for some reason it was T-Mobile like the mytouch4g and not verizon it was weird then i went to undo it and rebooted it then it ended up freezing on the THUNDERBOLT sign w/ the clouds and all that stuff
- 05-16-2011, 07:35 PM
Thread Author #16
- 05-17-2011, 12:05 AM #17
Does your phone turn on at all now? or just get stuck in a boot loop?
- 05-17-2011, 04:14 PM
Thread Author #18
- 05-18-2011, 06:01 AM
Thread Author #19
Reply
