1. qudwls6933's Avatar
    im using windows 7 64bit and trying to learn adb and cmd
    so i can root my tb..
    i was watching youtube video for how to install adb and
    after installing adb and drivers and added adb on system variables
    i type cmd and then typed C:\android-sdk-windows\platform-tools
    after that i typed adb devices but got an error
    C:\android-sdk-windows\platform-tools\adb.exe is not a valid Win32 application.
    what do i have to do here?? T.T
    05-15-2011 10:53 PM
  2. aBoldPatriotsFan's Avatar
    Are you plugged in and in disk drive mode with debugging mode checked?
    Sent from Tapatalk using my ThunderBolt
    05-15-2011 11:04 PM
  3. DroidXcon's Avatar
    if you are following either of the tutorials mac or windows in the roms and hacks section you shouldnt need to install sdk ...i would go reread the threads carefullly and you will be set.
    05-15-2011 11:08 PM
  4. nate44's Avatar
    I appreciate you sticking around here, and helping people out.
    How you liking the Charge?
    05-15-2011 11:34 PM
  5. DroidXcon's Avatar
    Thanks
    Loving it so far i have not had any down time in data. and i am getting double the battery life its lighter and the screen is awesome.
    nate44 likes this.
    05-15-2011 11:38 PM
  6. qudwls6933's Avatar
    yes.. everything are checked ^^
    05-16-2011 09:22 AM
  7. DroidXcon's Avatar
    Just download and use my autoroot
    Sent from my SCH-I510 using Tapatalk
    05-16-2011 09:30 AM
