Results 1 to 11 of 11
    Default Problems with contacts after switching ROMs?
    I was trying to switch from the Desensed DasBAMF 1.7 Remix to the regular DasBAMF 1.7 Remix and after backing up everything with Titanium Backup and restoring what I thought was everything I had no contacts. I've since gone back to the Nandroid before I tried to do this but I would like to go back to the Sense version. Any suggestions?
  2. #2
    Default
    Titanium is primarily for backing up apps, use "My Backup" for grabbing your settings and stuff like contacts, SMS, calendar, etc.
    http://forum.androidcentral.com/thun...-new-roms.html
  3. #3
    ShawnMeds23's Avatar
    Posts
    Global Posts
    139 Global Posts
    ROM
    Bamf on HTC. Stock prime
    Default
    Put all your contacts in to googel(gmail). Once you load gmail on the initial set up. All you contacts will be there.
    Default
    Thanks, I'll be using My Backup from now on. I was only concerned because I'd switched ROMs a couple times doing what I did last night and my contacts came through just fine.
  5. #5
    Upstreammiami's Avatar
    Posts
    Global Posts
    2,101 Global Posts
    ROM
    JB
    Default
    best is to load ur contacts to google very easy to do..... every time u load a new rom google auto will restore your contacts
    I'm the ROOT man
    G Talk: Upstreammiami3o5
    Let me help you ROOT your phone
  6. #6
    Default
    Quote Originally Posted by Upstreammiami View Post
    Since im new to the gmail thing how do I load all my contacts from my phone to gmail?
    Thank you
  7. #7
    Posts
    Global Posts
    2,101 Global Posts
    ROM
    JB
    Default
    go to your conatcs hit menu and save them to your sdcard, then delete all of them , after that hit menu and import from sdcard then select to your google account NOT PHONE
    I'm the ROOT man
  8. #8
    Default
    Thank you
  9. #9
    mclarryjr's Avatar
    Retired Moderator
    Posts
    Global Posts
    6,243 Global Posts
    ROM
    NOS M7 Sense 5.0
    Default
    Nice to see you back
  10. #10
    Posts
    Global Posts
    2,101 Global Posts
    ROM
    JB
    Default
    Quote Originally Posted by mclarryjr View Post
    i know man thanks its been a while feel like a rookie haha
    I'm the ROOT man
  11. #11
    EisBlade's Avatar
    Posts
    Global Posts
    68 Global Posts
    ROM
    das BAMF 1.8.6 NTE
    Default
    That's what I was doing wrong, selecting Phone when importing from the SD card. I went from 350 contacts to 1600+ before catching the mistake. Yesterday I was down to 500+ after manual deletion until I read this How-To. Thanks sent, Miami.
    JT
    Wake Forest, NC
    Motorola 325i (flip) -> DROID X -> Thunderbolt (running Th3ory v4.0)
