First time thread starter, long time reader, you guys are awesome and would really appreciate it if you can help a newb out! I just rooted my phone for the first time a few hours ago thanks to the help of the videos over at xda. Rooting went smoothly, so once that was done I figured I'd see what all the hype about das bamf 2.0-5 was. Watched this video:
YouTube - How to ROM: HTC Thunderbolt Das Bamf 2.0-5, and couldnt really understand what to do when he went into the command prompt. At one point he says you dont have to do this (install the kernal?) so I skipped it and booted up the phone. Now, I dont have a radio I'm assuming because I have no service. Can someone direct me to a step by step guide to install the new radio? Again this is my first time doing this so the guide needs to be in laymen terms. All help is appreciated. I've relaxed a bit but at first I thought I bricked the phone lol...hopefully I can get this phone up and running!
Thanks,
JV
before root=phone on froyo with froyo radio
after root=phone on froyo with froyo radio
installing das bamf 2.0.5 (a gingerbread ROM)--requires flashing a Gingerbread radio (MR2 Radio leak/official--i'd hold off on MR2.5 until more people confirm it's stable)
that's why you're without service
i'll compile/give you a link to the flashing a radio in very simple terms,
1. Download the desired radio file to the root of your SD card ((root, in this case, means do NOT place it in any folder, make sure it's at the top of your folder heirarchy)
2. Rename the file to PG05IMG.ZIP (if it shows as "PG05IMG.
ZIP.ZIP" then remove the first zip that i highlighted
3. check md5. don't know how? Install Astro File Manager, navigate to the radio file, long press the file, Properties, compare the MD5Sum vs the MD5Sum given on the Radio download page---if they don't match, it's a bad download!)
**critical**make sure Fast Boot is NOT enabled on your phone (menu>settings>power)--if it's Enabled (check marked) then you can NOT access the Bootloader function
4. Hold the Power button down, Choose Restart
5. Choose Bootloader
6.The phone will boot into Hboot then Bootloader, It should see the PG05IMG.zip and ask if you want to apply the zip.
7. Use the volume up button to select "yes"
8. Once its done flashing, use the volume buttons to confirm you want to reboot the phone and you should have a new radio.
IMPORTANT: Remember to remove or rename the PG05IMG.zip from the
root of your sd card when you're done--otherwise any time you boot into BOOTLOADER your phone will always attempt to update the file & you'll be S-O-L & frustrated.
it's safe to create a folder on your sd card called "ROM Radios" and creating sub folders for "GB" and "FROYO" in which you could place this Gingerbread Radio--if you want to switch back to it after flashing a Froyo ROM & Froyo Radio
