wild1z
No Facebook app in the market yet, not supported on the Thrive. Neither is NetFlix. I guess I should be patient.
Thanks, I'm with you about about being parnoid about giving permissions. As it turns out, it has several games that I like, already loaded.
As far as the calendar, probably, not going to worry with the it, just was trying things to see how they worked.
Did you sign up for the trial of Kaspersky? or go with a different one, or non at all.
Thanks, for everyones help. I'm sure I will have more.
When I am closing a tab, it seems sort of hard to, I guess to touch it in the right spot to close it, is anyone else having this problem? are do you just not worry about closing the tabs and just go back to the home screen?
No dumb questions! There is nothing wrong with curiosity before you are about to spend a substantial amount of money.I see my question about the docking station port, was really a dumb question, lol, just watched a video on youtube, I felt sure it had to come off, just seems hard to get off and I wanted to make sure in case I bought one.
The close button on the tabs are very small, I usually have to try a few times before I hit them right on. I'd rather have to try a few times than accidentally hit it all the time though.... Trade offs I guess.
When I did the update for the Thrive, there was never a screen, showing download complete, how do I know if the update, downloaded, It rebooted once.
Go to the "Service Station" app in your app list when you are connected to a wireless network and pick "Check for Updates" in the left column. If it doesn't find anything, you are up to date.
The last time I checked my Service Station an update for Toshiba App Place (7/20) was listed. Does anyone know what this update does? I've not yet installed it . . .
what is the difference is the App place market thats comes on the thrive and the Androidcentral market? will they both be ok for downloading from?
to download a malware protection like Lookout, is it available from the app store? are do I just go to there web site, while on my Thrive and download it.
I think I would feel better if I had something on it. lol
Does anyone know how good there free one is compared to the pay?
will you download the free one, if you do?If I decide to try lookout, I will go to the lookout site and download it there.
Yes, this has happened to me 3 times since I got it last week.I shut the Thrive down last night, this morning when I woke up it was in the sleep mode, anyone else had this happen? Not sure about this. lol
