Page 2 of 3 FirstFirst 123 LastLast
Results 26 to 50 of 51
  1. #26
    djisia87's Avatar
    Posts
    Global Posts
    93 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    CleanROM ICS
    Default
    looking for OS for mesmerize....?
  2. #27
    KAR#AC's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Takes great pictures actually. I use it quite a bit. The vignette setting is pretty nice. I also downloaded the Vignette Camera. The demo version doesn't allow to use the 5mp, so for as little as $3.99, you can have the full version. Lots of creative freedom with that app.
  3. #28
    Viperlocc's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Hi, was wondering if there is a way to take the shortcut button for airplane mode out of the notification area? I have a problem for some reason when I am talking to someone on the phone it will turn the screen back on from moving around and for some reason my ear will open notification and push airplane mode and well it hangs up on people.
    Also was wondering if anyone had a problem with the phone dropping calls even out in the open when you have a good signal?
  4. #29
    Chubby Bruiser's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Hello. I am new to Android, I have the Mesmerize and have several questions.
    How do you save a pic received in a text to the gallery?
    How do you set ringtones for contacts?
    When I hook my usb / phone up to my laptop I get nothing. What am I doing wrong.
  5. #30
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    I dont mean to be a pest but i was curious if anyone knew the answers to my questions? Thank you.
  6. #31
    TimH's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Quote Originally Posted by Chubby Bruiser View Post
    click on the picture in the message, go to menu, attached items, check the box, hit save.
    click on contacts, open the contact you want, menu, edit, scroll down to ringtone, pick which one you want, hit save.
    when you hook your phone up usb, you should see the folders on the sd card in my computer. doesn't really show up as a separate drive.
  7. #32
    almaguer.a.m's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    You can go to Settings and then go to USB Settings and select from the following options Samsung Kies or Mass Storage or Ask on Connection.
    Hope it helps...
  8. #33
    akellar's Avatar
    Posts
    Global Posts
    2 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default No system update in menu
    Am I missing something? The system update option in About Phone is not found. Does this only show up if an update is available or has USCC locked it down for some reason?
  9. #34
    skipwms's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Hi, I've been trying to add some of my ringtones for in coming texts, I don't like the ones that are set in the phone. I'm able to add for in coming call but not in coming texts. I read something about rooting do you think there is a way with that if there's no other way. If there is a way can let me know set by set, I'm not really quick with the phone yet LOL thanks
  10. #35
    bdc1987's Avatar
    Posts
    Global Posts
    7 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    ive downloaded some ringtones/notifications from myxer.com and they automatically show up in the respective fields when going to select them as such, but for the life of me i cannot find them anywhere on the phones internal and external memory. i have a folder setup on my sd card for such items. i know on my desire everything i downloaded showed up in a download folder on my sd card but with my mesmerize only pictures that i download show up there. any insight or advice would be greatly appreciated.
  11. #36
    laney12186's Avatar
    Posts
    Global Posts
    270 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    This may sound like a ridiculous question but how do I get the swype keyboard to work when I'm texting? I've gone through the tutorials and checked all the settings but I mist be missing something. Can anybody help?
  12. #37
    rpfarrah's Avatar
    Posts
    Global Posts
    1,008 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    In a texting field, tap and hold for a second: you will get the option to select an "input method". Choose swype.
    laney12186 likes this.
  13. #38
    laney12186's Avatar
    Posts
    Global Posts
    270 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Thank you!
  14. #39
    laney12186's Avatar
    Posts
    Global Posts
    270 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    I have another question...is there a way to see what percentage of battery you have oft without downloading a battery indicator app? I can see where you look up what is using your battery and where you can see the status as either charging or not charging but I haven't found an actual percentage. Is it possible to see it without an app?
  15. #40
    rpfarrah's Avatar
    Posts
    Global Posts
    1,008 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Quote Originally Posted by laney12186 View Post
    You can go to menu>settings>about phone> battery, I believe. Some ROMs will have a battery percentage in the notification bar, but other than that, I think you'd have to use an app.
  16. #41
    laney12186's Avatar
    Posts
    Global Posts
    270 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    That's where it tells me what's been using the battery an whether its charging or not...no percentages. Guess I need an apparently for that.
  17. #42
    dstephenson447's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    First, thanks for looking at my question and apologies if it's already been covered. Is anyone else having the problem of the phone being a dead stick after unplugging it from the charger? The only working thing on it is email and web browsing. All phone functions do not work. No calls can be received or made and the same with text messages. At first, my phone was the only one but now my wifes' phone is doing the same thing. any solutions or suggestions are greatly appreciated.
    Thanks!
  18. #43
    laney12186's Avatar
    Posts
    Global Posts
    270 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    I'm not having that problem...do you have airplane mode on or have tumour checked your settings to see if something has been inadvertantly been changed?
  19. #44
    ozarkchick's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Quote Originally Posted by i4get75 View Post
    XDA put out an app called NoLED that does great for that. It lights up a icon on the screen when you get emails or sms/mms. It works great and doesn't really effect your battery at all. The rest of the screen stays as dark as it does when it's off.
    THANK YOU for that suggestion. I received the Mesmerize as a gift yesterday; neither the buyer or I realized there's no LED light on the phone. Since I'm deaf, that means I either have to always have the phone in-hand or keep turning it on to see if I have new messages. I just downloaded it and am waiting for a message to come through so I can see if it works for me.
  20. #45
    spfsnana's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Mesmerize text pictures
    Good morning! I have a new Mesmerize. I received a text with a picture attached and was able to figure out how to save it. However, I am clueless as to where it was saved! I have looked in my files and the gallery and the picture isn't there. Please give me an idea where to look! This is driving me crazy!
    Thank you!
    Stephanie
  21. #46
    keegs3225's Avatar
    Posts
    Global Posts
    144 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Hello, I'm new to the android world as of last night! I traded in my blackberry (and the crackbery world unfortunately) and I can't understand what took me so long to do it! This phone and OS are AMAZING! I have already learned so much from all of you in the forums, but I did have a question - I tried the noLed app that was recommended for notifications but I could not get it to work. My phone is always on vibrate so I would really love an app that would light up my screen or something to notify me silently. Any suggestions? Thank you in advance!
  22. #47
    keegs3225's Avatar
    Posts
    Global Posts
    144 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Also, can anyone shed some light on what is on the left side of the speaker ear piece? Is that a front facing camera???
  23. #48
    maqclark's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Can anyone tell me how to get the music player to close after I open it? And how do you stop a song from playing? I can only pause a song, but I cannot get the song to stop. Can anyone help?
  24. #49
    MrWolfox's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    How should I go about updating my phone?
  25. #50
    hollskii's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: We've got a Mesmerize, throw questions at us!
    Hey I have a question...I have a mesmerize and just downloaded some Ringtones from myxer and when I try to set them as a ringer or text tone all that comes up to choose from is zedge, the other app I have and the android system tones....how do I set those?? Thanks.
