Sync my Blackberry contacts to the Samsung Note 2 issues with company names
I used 2can ap to sync my BB contacts over to the Note 2. It sync'd the contacts with the note section but the contacts with jst a business name it ported them as an "unknown" contact. . Can you pre-set the Note 2 to accept orgnaization names in the contacts during a sync? I have 2500 contacts some with just business names as the contact. I need to have all my organizations names in the contact as well as the prinicples name. I want to be able to search by either. Can this be done?
Re: Sync my Blackberry contacts to the Samsung Note 2 issues with company names
Are you trying to do this yourself or did you have your carrier transfer the contacts when you bought the phone. If not this I would suggest having your carrier transfer the contacts in the store, it usually goes much smoother this way.
I would have recommended syncing with a desktop PIM like Outlook where you could have modified the contacts more easily.
