1. andunn31's Avatar
    My wife had this charger for her LG enV Touch:
    Micro-USB Car Charger - Verizon Wireless Original
    Will this also work for charging her Droid Charge? It has the same connection.
    07-11-2011 08:48 PM
  2. Halo's Avatar
    Yes. I use my OG Droid car charger for my Charge.
    andunn31 likes this.
    07-11-2011 08:50 PM
  3. andunn31's Avatar
    Awesome! Saved me a few bucks!
    07-11-2011 08:54 PM
  4. basscadet's Avatar
    I am using the cheapo car charger that came with it from Costco and it works really well.
    07-12-2011 12:13 PM
  5. winnersmw's Avatar
    Generic chargers, VZW's charger included, will indeed charge the phone without any problems. However, if you're using battery-intensive apps such as GPS, or running multiple semi-intensive apps at once, the VZW charger won't be able to keep up with the depletion of the battery. In other words, your battery will still drain even though it's plugged in. There's been a lot of talk about this on the forums and the concensus is that you're going to need a charger that pushes at least 1 ampere of electricity (1,000 mAh). The VZW charger pushes 750 mAh.
    07-12-2011 01:52 PM
  6. rescueswimmer's Avatar
    May want to look into one of these rapid rate charger cause if your on 4g and gps this seemed to slowly give me a charge then
    Amazon.com: Motorola Vehicle Power Adapter micro-USB Rapid Rate Charger: Cell Phones & Accessories
    07-12-2011 10:07 PM
  7. fortesquieu's Avatar
    This is the best charger ever! I've had it since last year, and it's still going strong! From Dincy to Fassy to Chargy.
    07-12-2011 10:23 PM
  8. atheron121's Avatar
    Just purchased this charger about a week ago. Works REALLY WELL!!! Also, can't beat the price. One note of caution, though - plugging the charger/phone into the auxiliary charger port, the battery may overheat and the charging will pause. Use the primary port (I used it with GPS on the trip from NY to PA, almost 3 hours, no overheating, battery stayed at 100%).
    07-13-2011 08:24 AM
