1. DawgPoundMBA's Avatar
    I like the different ROMs on here but I am unsure of what is a proper amount to donate and to whom? Someone experienced should put together something that gives a type of user and normal donation amount like:
    Student: $10
    Young professional: $25
    Experienced professional: $50
    Baller: $100
    or something similar. If a good guide was developed then you probably would get more donations. If one exists then smack me and make it more evident
    07-13-2011 11:39 PM
  2. Cruiserdude's Avatar
    This is probably gonna get closed...
    But you donate what you feel like donating to those who you feel really helped you out. Of course it depends on your finances, but its a personal decision. There's people on here who have donated hundreds of dollars, and a few who have even bought phones for devs, and there are many who haven't been able to donate anything at all. These devs aren't in it for the money, but they definitely appreciate some thanks for their time. Many put that money right back into getting new hardware to develop on. But if you can't afford much at all that's just fine, none of them are going to hate you for it.
    But most people donate when a dev comes out with a really useful tool, patch, kernel, etc, or when their favorite ROM dev cooks up something new. The amount and frequency is of course completely up to you, there is not and never will be a guide.
    We have a ton of devs already for this device, look in the development section, or check out xda or rootzwiki, other great sites. When you find yourself using certain tools, kernels, roms, themes, etc that you like, consider a donation to the devs for their time. And if you can't afford it, that's fine, just help them spread the word, and consider helping them test their work if you've got the time.
    But again, no one can tell you how much to donate, its based on whatever you can afford and feel like is right.
    SuperJonCA and marisajoy like this.
    07-13-2011 11:58 PM
  3. zeuswsu's Avatar
    I was wondering the same thing....I never used to donate at all. Now I donate 10 bucks or so if I find something that I am using all the time. Cruiserdude pretty much hits it on the head.
    07-14-2011 12:43 AM
  4. jkeene81's Avatar
    Yea def could not have said it better myself Cruiserdude!
    07-14-2011 08:40 AM
