Results 1 to 17 of 17
    Zzeyfzz's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default i hear them, they can't hear me
    So I have had the charge for a few weeks, and there are times when I make calls, and the person on the other side can hear me, then puts me on hold, and then the next person picks up to talk to me and can't hear me anymore and hangs up. Or, I'll call and they immediately hang up because they can't hear me. I can hear them perfectly well, and then I look at my phone to see if I muted it with my face (which is not true because the mute button isn't even on the screen at that point) or I curse at my bluetooth speaker if I happen to be calling while I'm driving. I usually just call back and then they can again hear me. This happens at least once a day. The reception is usually in the 2-3 bar range or even max when I am driving around and when I'm at home making calls, there aren't any reception problems.
    This has been happening a couple times per day, and I brought it to the verizon store and all they did was hard reset my phone a few days ago and told me to not to download any questionable apps. I've gotten everything off the market or the amazon app store and I haven't heard of anyone getting android viruses anyway. I never had this problem with my just-retired old phone, the Palm Centro. Anyway, this is still happening to me now. Is this a real problem? Or is to be expected with this phone? I don't think this makes any difference, but I'm living in California and still using my old New Jersey cell number. Does that change anything?
  2. #2
    ellje's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: i hear them, they can't hear me
    I've been having the same exact issue... although only with one contact, which is weird. He says that he has no issues with anyone else, either.
  3. #3
    shangrila9505#AC's Avatar
    Posts
    Global Posts
    11 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I've had my Charge for 24 hours and it just happened with me. I even attempted to call the other person back multiple times, but no avail. Eventually I just pulled the battery and everything was okay again. I do not think I will be keeping the phone; I will go back to my D X2.
    Zzeyfzz's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Ugh. So it's not just me. I will try resetting it in different ways and hope that it helps. I really like the phone otherwise.
  5. #5
    AndroidXTC's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    None
    Quote Originally Posted by Zzeyfzz View Post
    It's happened to me too. Not often but yes once in a while for sure. It might be a network issue who knows...
  6. #6
    trigun123478's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock rooted 4.04 IMM76K
    It also happen to me twice,once with bluttooth and the other without blutooth.It was with just one contact,also have trouble hearing her volume goes up and down.So when I am on a phone call with her she keeps asking what did I say and I have trouble hearing her. She is with verizon and also has the droid charge.Ive only had the phone a week.Went into verizon about it and they just wanted to do a factory reset,I declined and called customer service and she looked up my issue and said that the gingerbread update coming in mid august would fix call quality issues.
  7. #7
    jneusch's Avatar
    Posts
    Global Posts
    1,196 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I was just on the VZ community forum. This was listed as a known issue that has been escalated to Samsung for resolution. I am not having this issue myself, but thought I would share what I just saw over there.
  8. #8
    dressagerider's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I am on my second charge and have had the same problem with both. I love this phone!! However, the call quality is not the best and I am hoping this is fixed with an update.
  9. #9
    piizzadude's Avatar
    Banned
    Posts
    Global Posts
    5,774 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Something JB
    Default
    I am not sure where i read it but the update that should be coming soon is said to address call issues
    Charged up post!
  10. #10
    Dnoravian's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    i had this issue a few times when i first bought the phone. it was when i was on bluetooth and i would make a call by selecting a contact and then clicking on a specific number in that contact to dial. Again, it only happened when i was in bluetooth. weird.
  11. #11
    atlantar6's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Happened a few times to me, never on Bluetooth
  12. #12
    fortesquieu's Avatar
    Posts
    Global Posts
    93 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    So did anyone find a fix for this?
    I tried 3 different phone numbers just now, all of them had problems hearing me when I was able to hear them find. Not on bluetooth.
  13. #13
    girlymissjulie's Avatar
    Posts
    Global Posts
    94 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    GummyCharged GBE
    Default
    Quote Originally Posted by fortesquieu View Post
    I had the same issue too when I was on EE4. Since I've been on Gingerbread, I have never had it happen once. It still happens with my husband's when he calls me from his EE4 Charge. Definitely an issue that seems to be fixed with Gingerbread.
  14. #14
    Lynn Browning's Avatar
    Posts
    Global Posts
    1 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by girlymissjulie View Post
  15. #15
    Posts
    Global Posts
    1 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
  16. #16
    Posts
    Global Posts
    1 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
  17. #17
    Posts
    Global Posts
    1 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
