Struggling w/ battery
therealdetroit
I don't know what to do, but if I charge the phone to 100% leave on without being plugged in it dies overnight w/o gps & wifi on.......I constantly close apps to make sure only the ones I need to run are running throughout the day and this phones battery time is AWFUL! I plug in repeatedly throughout the day even when I hardly talk on the thing......What should I do?
TauntingBull
175
7
Is it rooted and romed? Have you calibrated the battery?
Salil
56
I have the exact same problem. With GPS and WIFI turned off the battery doesn't even last 10 hours with light use. Is it necessary to root it to save battery life?
delco714
658
20
18
Hell no. if I did that I'd get more than the 20 hr I get now with moderate use. There has to be some common denominator bw you all
daThomas#AC
72
3
Out of the box I have experienced easily a full days moderate use with 4G on. No problem.
Something is eating your battery. If it's happening overnight then you should be able to diagnose it with the About Phone --> Battery Use info since your display should remain off during that time.
mcbrett
Active member
Mar 25, 2011
36
My best guess is you may live somewhere with a weak connection- and your antenna is consuming mucho energy trying to find/secure a signal. This happens to me when I'm at work, but when I'm away from work the battery lasts much longer.
rorkin
64
Might want to test that and put into airplane mode overnight to see how the battery holds up
NHLou
123
4
I agree with this comment. If you are in a 3G area, turn off LTE and go into CDMA mode. You may also want to disable background data and see if that improves battery life. You can definitely get better battery life out of the Charge, but you need to "manage" it.
YzBrad99
Active member
Jun 17, 2010
26
Try turning your mobile data off and see how that effects the battery. If your in a 3G area and your searching for 4G, it will drink the battery.
ddemlong
173
15
hmm, odd , I have 4g and its always on, and I easily get 10 hours, take it to a verizon store and have em test the battery,
GPS on, gotta remember its only a on demand thing, as long as you're not actively using it, its not on. Data ON, only thing that syncs is Gmail.
Biggest killer is ALWAYS the screen. Set the brightness to about 23-30% and that should help.
fallingOutOfLoveWfithTech
