Results 1 to 15 of 15
    Default Need help with launchers
    I don't like touchwiz and it crashes a lot on me so I downloaded go launcher. However I think it is just running on top of tw. How do I stop tw from running?
  2. #2
    TopJimmy2's Avatar
    Posts
    Global Posts
    16 Global Posts
    Default Re: Need help with launchers
    If you reboot the phone, it should prompt you to select a launcher and give you the two choices. Just check the box at the bottom and touch Go Launcher and you should be good to go.
  3. #3
    richardpandy's Avatar
    Posts
    Global Posts
    238 Global Posts
    ROM
    Stock w/ Root
    Yeah, once you hit the Home Button, set it as default and you are good to go. I use Go Launcher as well and really enjoy it. I don't care for the notification system they have though. Never seems to work properly so I got rid of it.
  4. #4
    I run launcher pro and love it....
  5. #5
    Yes, touchwiz is part of the samsung platform. so yes it is still running and taking up processing power and resources. the only way you will not be running it is to hope for and install CM7 which will not have touchwiz integrated and will be native gingerbread.
    i guess unless you are into rooting and romming i wouldn't worry too much
  6. #6
    Whenever you download a new launcher just press the home button and select the "Use by default" then select the launcher. To get back to stock launcher or switch between launchers go in to settings>applications>manage applications>-select launcher you're currently using->Clear defaults Now just press the home button like before.
  7. #7
    Make sure u remove all the Widgets from touch Wis launcher
  8. #8
    sicario666's Avatar
    AndroidSkull
    Posts
    Global Posts
    3,349 Global Posts
    ROM
    Vitreous,JellyBelly,OEM
    Default
    LPP is an excellent launcher. Alot of customization available
    ***GET IN WHERE YOU FIT IN***
    Snitches get stitches
    Boneyard-D1,Dinc,dX,Gtab7",Tbolt,iPad1,Bionic,Xoom,iPad2,Charge,GNexus,SGS3,Razr Maxx,Nexus7...the list shall continue
    Living Dead-iPad3,GalaxyNexus,Razr MaxxHD
  9. #9
    mdoyal1's Avatar
    Posts
    ROM
    Teamhacksungs ICS port
    I use just a plain ol' Gingerbread launcher. Works really well even on an underclocked CPU. I like the simplicity of them
  10. #10
    Default
    You can download Homeswitcher from the market that will allow you to change launchers very easily.
    Sent from my stock Atrix 2.3.4 using Tapa
  11. #11
    olorin's Avatar
    Posts
    Global Posts
    57 Global Posts
    You can use another launcher without rooting, just more efficient when rooted. I personally prefer GO launcher because it's more customizable than LP & ADW, but all three are good. I was running GO Launcher over my stock ROM for 6 months without root. But, once I finally rooted, it was much faster!
  12. #12
    I use gumYcharged 2.0 Witch has the stock launcher. And on top of that I run launcher pro plus. Runs great.
  13. #13
    Default
    Just curious but what do you mean your launcher is crashing?
  14. #14
    I use home switcher to go from one to the other. It's a nice app.
  15. #15
    jlgroves1's Avatar
    Posts
    ROM
    RCmix3D / ICS beta
    I had the problem of Go launcher crashing on an unrooted htc Inspire. By crashing I mean that about once every few days The phone would completely lock up when certain apps were open. All tactile buttons would become unresponsive, even the power button, and the only way to restore function was to remove the battery. I uninstalled Go launcher a few days ago, and have not had the problem running stock sense UI.
    Rooting would probably alleviate the problem but I'm not sure if I really need Go launcher that badly. I really did like it when it worked though. Another launcher I liked was the Regina launcher, it was really buggy though.
