So yesterday I went out and bought a Verizon Samsung Charge.
Consider me clueless, I enjoy the look and everything but hate that is has so much preloaded BS on it right out of the box. I also don't know what other 4G Android smartphone would have been a better choice on Verizon.
Should I have waited for a device later in the fall? I still have a while to return the device.
Should I root the device after the return period expires? I have no idea how to do this but understand that it is fairly easy. Then which root program should I use, I don't know any of the terminology and will fully admit to being a newb but I hear there are a ton of options for rooting and just wanted to get a better feel for all of this overwhelming information.
I know most of you guys are programers and have put a significant amount of time in to customize your device as best as possible but I just wanted to get a better idea of my new phone.
THANKS!
THANKS!
