Results 1 to 8 of 8
Like Tree1Likes
  • 1 Post By AndroidXTC
    Default My Charge Died
    I'm running a stock Charge. Not rooted etc... Yesterday I shut it down and put in a replacement battery. I hit the power up button, it starts the boot sequence and then just spins. Verizon is sending me a new phone. Has anyone else experienced this problem? The thing is bricked.
  2. #2
    piizzadude's Avatar
    Banned
    Posts
    Global Posts
    5,774 Global Posts
    ROM
    Something JB
    Default Re: My Charge Died
    was the battery an OEM or generic battery?
  3. #3
    AndroidXTC's Avatar
    Posts
    ROM
    None
    Hmmm sounds like a battery issue not the phone.
    NHLou likes this.
  4. #4
    was it a cheap battery off eBay......
  5. #5
    piizzadude's Avatar
    Banned
    Posts
    Global Posts
    5,774 Global Posts
    ROM
    Something JB
    What happens when you put the OEM back in? There is a little piece of code in the kernel that will not allow generic batteries on Samsung devices. It will not allow them to charge (but they at least ran on the Fassy) maybe they changed it for the Charge that it would not even run.
  6. #6
    Default
    Quote Originally Posted by piizzadude View Post
    I have Hyperion batteries and they run as well as oem.
  7. #7
    Lodingi's Avatar
    Posts
    Global Posts
    707 Global Posts
    Default
    Quote Originally Posted by atlantar6 View Post
    So when you put the original battery back in all was well?
    Sent from my SCH-I510 using Tapatalk
  8. #8
    piizzadude's Avatar
    Banned
    Posts
    Global Posts
    5,774 Global Posts
    ROM
    Something JB
    maybe they are considered OEM by samsung but the stupid generics are blocked
