Results 1 to 11 of 11
- 09-28-2011, 02:52 AM
Thread Author #1
Silence ringer during incoming call
When I get an incoming call, I am not able to silence the ringer. I have options to answer call, reject call or "reject with new message". I click the volume rocker but this does not turn off the ringer. So, does anyone know how to turn off the ringer during an incoming call?
- 09-28-2011, 09:01 AM #2
- 09-28-2011, 11:31 AM
Thread Author #3
- 09-28-2011, 12:26 PM #4
Re: Silence ringer during incoming call
i silence mine all the time... alot of the times "reject with a message" doesnt appear
when my screen is locked the 3 puzzle pieces show up with mute icon, answer, and reject
when my screen is unlocked i get 3 buttons answer, mute ,and reject - 09-28-2011, 12:31 PM
Thread Author #5
- 09-28-2011, 12:35 PM #6
thats a good question. i am here at work dialing my phone over in different screens and situations trying to get the "reject with a message" and it wont pop up
- 09-29-2011, 01:40 PM #7
I simply press the lock screen/power button (thanks Delco714
nice!) (right side phone). The call continues to 'ring' but is silent.
This works for me when the phone is both locked and unlocked.
When the phone is locked; as an aside, I do get the 'message' puzzle piece.Last edited by Kopter; 09-29-2011 at 01:50 PM. Reason: to add the word POWER.. thanks to Delco714
- 09-29-2011, 01:41 PM #8
- 10-11-2011, 11:39 AM #9
go to your setting and change your lockscreen from slide glass to slide puzzle. then you will have the option. to silence your phone from the screen.
- 10-12-2011, 10:13 AM
Thread Author #10
- 10-12-2011, 10:50 PM #11
I dont have any problems at all with silentin my Charge. i just use the volume rocker to bring volume up or down to nothing,, try using the DSP app thats on the GBE gummy.. you can increase or select small speakers room or what floats the boat or even use a mp3 as a ringtone and make it ring as you please,
there is a equalizer that is user friendly...
Reply
