1. Kage87Z's Avatar
    I'm running GC GBE 2.0 And TRYING to run NoLED.
    I can't get the lockscreen to come up.
    Unfortunately, for NoLED TO work, I understand you MUST have a lock screen.
    I've followed the FAQ for the NoLED app, (applications>running applications>NoLED) and it shows 1 process and 2 services running.
    I've tried all of the adjustments in settings that I can find concerning the lockscreen, but with no luck.
    Any suggestions?
    10-07-2011 02:24 AM
  2. Landshark's Avatar
    Any suggestions?
    Did you go into TSM parts=>lockscreen settings, and check then uncheck disable lockscreens? For some reason with the port of TSM parts over to the Charge you have to toggle that setting to get lockscreens to show up.
    Kage87Z likes this.
    10-10-2011 02:53 PM
  3. Kage87Z's Avatar
    That hit it.
    I'd been there before and was sure I had done that... but it was checked, and unchecking it solved the problem.
    Thank you, sir... well played!
    10-11-2011 10:58 AM
  4. Landshark's Avatar
    That hit it.
    You're welcome. That's what AC is for.
    10-11-2011 11:55 AM
