Droid charge won't format or read sd card..
jbomb11
Banned
Mar 22, 2010
606
13
Anyone able to help with this?
I have tried obvious factory reset, change of sd cards, etc... Nothing works.
Sent from my SCH-I510 using Tapatalk
chrstdvd
87
I see that you have been around a while so my initial question is mute. Has it ever worked, or did this just happen? After I rooted with Frayo, I had to use file to fix this problem and when I rooted GB I believe a file was included in that to fix the problem but I just read that section and do not see the file listed. You might go over there and look around.
http://www.toms-world.org/android/
I erased the original file from my sd card and can not remember the name. I had something to do with going from RFS to EXtT4 file system.
Reactions: jbomb11
