DEAL OF THE DAY: Save 60% on the LLOYD Flex Case for LG Nexus 4!
Results 1 to 2 of 2
    jbomb11's Avatar
    Posts
    Global Posts
    528 Global Posts
    Default Droid charge won't format or read sd card..
    Anyone able to help with this?
    I have tried obvious factory reset, change of sd cards, etc... Nothing works.
    Sent from my SCH-I510 using Tapatalk
  2. #2
    chrstdvd's Avatar
    Posts
    Global Posts
    251 Global Posts
    Default Re: Droid charge won't format or read sd card..
    I see that you have been around a while so my initial question is mute. Has it ever worked, or did this just happen? After I rooted with Frayo, I had to use file to fix this problem and when I rooted GB I believe a file was included in that to fix the problem but I just read that section and do not see the file listed. You might go over there and look around.
    I erased the original file from my sd card and can not remember the name. I had something to do with going from RFS to EXtT4 file system.
    Thanked by:
