Results 1 to 6 of 6
Like Tree1Likes
  • 1 Post By Bob61
    expidia's Avatar
    Posts
    Global Posts
    740 Global Posts
    Default Customize bottom 4 buttons (not the hard ones)
    Prior to the GB update I thought I had swapped one of the bottom 4 icons for a Handcent icon.
    I then moved the stock Message button onto another page.
    Can we still customize those 4 buttons? We used to be able to hold them down and move them off the home screen.
    Thx
    Samsung Droid Charge on VZ
  2. #2
    Default Re: Customize bottom 4 buttons (not the hard ones)
    Tap the Applications icon on the launcher. When you're looking at all your apps just hit the menu button and select "Edit". You can change 3 of the apps.
    expidia's Avatar
    Posts
    Global Posts
    740 Global Posts
    Your instructions seem to be the ones before I did the GB update. I used to go into settings>applications>manage applications and there was a little gear on top left that allowed me to edit 3 of those icon buttons (or clicking on the app). But since the GB update I don't see how to accomplish this anymore.
    I am not rooted.
  4. #4
    Bob61's Avatar
    Posts
    Global Posts
    1,880 Global Posts
    jmmurphy32 has already explained how to do it - but let's see if this helps you:
    1. Tap the Applications icon on the launcher.
    2. Hit the menu button and select "Edit" (or you can select the "gear" icon at the top left)
    3. Find the icon of the app you want to bring into the bottom bar
    4. Touch and hold the icon to select it, then drag it to the bottom bar
    5. Repeat as necessary
    The process you are going through isn't correct and wasn't correct prior to GB either.
    lordbear likes this.
    expidia's Avatar
    Posts
    Global Posts
    740 Global Posts
    Thanks for both of your replies. I finally got it by following your instructions exactly.
    When I read the first reply the word launcher threw me. I thought the poster thought I was using one of those launcher program from the app store.
  6. #6
    Smile Re: Customize bottom 4 buttons (not the hard ones)
    Although not exactly what you were asking for but check out this new "one of a kind" application related to customizing hard keys :
