1. medic673's Avatar
    Is this normal? i just got this for my kiddo and you loss data during calls. this is the first 4g phone i seen do this. suggestions?
    02-04-2012 05:56 PM
  2. santos's Avatar
    What do you mean data loss during phone calls?? Do you mean you are downloading something, a phone call comes in and it interrupts your download?
    Or do you mean you are using data while on a phone call? 4G data can be active at the same time as a call.
    02-04-2012 06:27 PM
  3. Davidoo's Avatar
    I have always been able to use 4G data during calls as well. I can surf and use data while on a call.
    02-04-2012 07:16 PM
  4. Jhett's Avatar
    Really? I thought that one of the differences between Verizon and AT&T was that only AT&T allowed you to use data and voice at the same time. Is that something that changed with the advent of 4G?
    02-04-2012 08:06 PM
  5. santos's Avatar
    AT&T's 3g network allows simultaneous voice and data. Verizons 3g does not. But with 4G, you can.
    02-04-2012 08:48 PM
  6. medic673's Avatar
    Thats not quite right, my Thunderbolt does it just fine. To answer the question, when I make a call, all my data service goes out. This is the first "smart phone" that has ever done this. I was just wondering if there is something wrong with the phone or setting wrong. It comes on fine when the call ends.
    Suggestions?
    02-05-2012 07:23 AM
  7. piizzadude's Avatar
    I am going to guess it is the phone. I talk and use data at the same time a lot for work, nothing drops out for.me
    Charged up post!
    02-05-2012 01:18 PM
  8. medic673's Avatar
    I was told it was the radio that the calls and data are on the same radio and you can't get it to work on 3G only 4G? Anyone heard this before? I have to call shenanigans or something
    02-06-2012 05:25 PM
  9. kraisydave's Avatar
    It is a CDMA vs GSM thing. GSM carriers like AT&T and most all around the world have a system that permits calls and data to work at the same time as these are independent services.
    CDMA is older and only supports calls or data. Another system added into CDMA with a separate functioning antenna such as 4g could in theory work. But for now its a no go. Welcome to Verizon...Sprint is the same also.
    Dave
    02-22-2012 09:14 AM
