1. Salil's Avatar
    Hello Friends,
    My phone is sometimes extremely extremely sluggish to the point that I wanna throw it out the windows. The Advanced Task Manager shows almost no apps running to kill. There are several services that are running but I don't know of any other way other to reboot the phone to kill them and then after sometime the phone becomes sluggish again. Any solutions?
    02-15-2012 04:06 AM
  2. W_A_Watson_II's Avatar
    Same problem here. When the GB update came out, the phone was fast and snappy for a long time, but has gradually gotten slower and more lag. Based on checking what apps/processes are running when it's slow, I've found that more and more apps are running in the background than did after the GB update.
    Looks like the apps have caught up with the GB update and now run even when you don't want or use them.
    It gripes me so much that I want to throw the phone at a Google or Verizion CEO when I see apps that I've never used or wanted running on the phone.
    Give me back my Motorola Flip Phone! It had great signal strength and reception!
    02-15-2012 08:08 AM
  3. bmann's Avatar
    It bothers me too, for what we spent on this phone we should be able to prevent bloatware without having to root and install ROMs. My home computer is an iMac, so I can't unbloat mine, but maybe you guys want to root and ROM, there are people on the forum who will screen share and help you do it.
    02-15-2012 09:29 AM
  4. piizzadude's Avatar
    Why not? There are instructions around here to root with a mac
    Charged up post!
    02-15-2012 02:18 PM
  5. trifecta's Avatar
    Mine has also gotten slow. Used to be crazy fast, now not even close.
    02-15-2012 09:06 PM
  6. hockeymn25's Avatar
    Charged up post!
    I'm rooted but dont know which rom would be best. Whats the least buggy simple rom out there?
    THX
    02-16-2012 09:50 AM
  7. piizzadude's Avatar
    THX
    Eclipse and Tweakstock are the winners as far as I know. I use tweakstock, no issues with it at all. I am not putting down Humble or infinity, but they are on hiatus.
    hockeymn25 likes this.
    02-16-2012 01:55 PM
  8. Newport Viper's Avatar
    My GF just started to complain about this too... So you are all saying no fixes??
    02-16-2012 03:28 PM
  9. Chocu1a's Avatar
    Root your Charge. Then install either Tweakstock (cleaned up stock rom, black & blue theme, very snappy) or Eclipse (ICS style rom, very fast, great custom blue theme). I have used both roms & currently have Eclipse on my Charge. It is awesome.
    02-17-2012 08:05 AM
  10. Chocoburger's Avatar
    The Droid Charge is a piece of crap on Froyo, it was much faster on OTA GB, did you update your phone to GB? Anyway, I'd still root and use a custom ROM. Don't be afraid, as long as you can follow instructions. I have not used Eclipse so I can't comment, but I am rocking Tweakstock for the past month and a half and it is AMAZING! I too wanted to throw my piece of crap Charge out the window last June, but now my phone is no longer sluggish.
    Verizon and Samsung are terrible programmers, these custom ROMers are 17,000 times better.
    02-17-2012 10:31 AM
  11. piizzadude's Avatar
    non rooted semi solution: I am not sure if you want to go this route but some launchers have a speed boost built in that helps with opening and transition speeds. I recommend launcher pro
    02-17-2012 12:31 PM
  12. Wanderist's Avatar
    I have this problem too on my Charge, along with occasional crashes where the phone won't come back on. I've had to pull the battery once. However I noticed the slowdown after I installed Go Launcher EX. I've been thinking that's where my problem is because the phone didnt start bogging down until I installed that. I've been willing to live with the issues because I'm afraid removing it will really crash the phone.
    Is anyone else who's having the slow down issue, running a non-stock launcher?
    02-18-2012 06:37 AM
  13. Chocu1a's Avatar
    If you want to see if it is the launcher(which I highly doubt, I am using golauncher), just go to settings-applications- manage application-scroll down to go launcher- click clear defaults. When you click your home button, you can now choose the stock TW launcher, or any other you have downloaded.
    Unless you are running a debloated rom, you will find it rather sluggish with all the crapware Verizon installed.
    02-18-2012 06:53 AM
  14. lostchord83's Avatar
    I've had my Charge for 6 months. Here's what I've learned regarding keeping it running smoothly. Keep the number of home pages to a minimum 3 or 4. Move apps to SD where possible, keeping in mind that some apps will not run properly from the card. This especially true regarding widgets. The quantity of number of apps installed on the phone also affects performance, keep installed apps to a minimum, leave the rest on the cloud. Live wallpaper will slow it down.
    True, none of these should matter, but they do. Keep your Charge "slim and trim" and it will run fine. As time goes by it will get "fat" again. Just clean it up.
    The Charge is a great multimedia machine, the Super Amoled display is alone worth the cost but you must manage it properly.
    Hope this helps.
    Sent from my Samsung SCH-I510 Droid Charge running Google's Android OS v2.3.6 using Tapatalk
    02-18-2012 07:12 AM
  15. piizzadude's Avatar
    I always run 7 screens without issue but otherwise I agree with the post above me.
    I never have lag but I guess it is just me. I get bored easily so I switch roms alot which involves a complete wipe so maybe that is my advantage
    Charged up post!
    02-18-2012 12:42 PM
  16. Chocoburger's Avatar
    I run Go Launcher EX and it runs stable and fast. Much faster than crap TouchWiz, I don't think your Go Launcher is slowing you down, this is assuming you're running a decent custom ROM. If you're running Verizon software, that is your problem. Fix it and your sluggishness will stop.
    As for the quantity of stuff on phone slowing it down, I don't experience that at all. I have around 180 apps installed and my phone is not sluggish, I have 17 GB of stuff being used on my micro SD card, movies, music, etc. Nope, not sluggish.
    If you're running Verizon software and claiming sluggish, then keep in mind it doesn't happen to people who run superior software on their phones. Check out Tweakstock, you'll see.
    02-18-2012 03:12 PM
  17. Damasterjj's Avatar
    mines runs smoothly with stock OTA,
    02-20-2012 08:11 AM
  18. Wilbur's Avatar
    Like a computer a reboot helps a great deal. I've made it a practice to reboot the Charge every morning or whenever it begins running sluggish. Problem solved for me. Running the downloadable Gingerbread version which was posted on this forum a few months back.
    02-22-2012 10:52 AM
  19. geochemical's Avatar
    You can also check to see if it is the low Class level of your microSDHC card:
    Slow smartphone? It's not the network, it's NAND flash - Computerworld
    I switched from the Verizon-provided Class 2 32 GB card to a Transcend Class 10 32 GB card and noticed a big difference in performance.
    02-25-2012 11:48 PM
  20. Salil's Avatar
    I figured out what was making my phone slow. It is when my phone connects with the
    'GOgroove FlexSMART X2 In-Car Bluetooth Advanced FM Transmitter '
    in my car. It is not slow when it connects to my motorola headset though. I was wondering as to if there are any tweaks that I can do to ease this problem?
    02-26-2012 02:15 AM
  21. hockeymn25's Avatar
    I am having trouble putting tweakstock on my charge. I put zip file on sd card, went into cmw mode found file but cant get it to load. Am i supposed to do something with the zip before putting onto sd card? Any help would be appreciated.
    THX
    03-01-2012 01:00 PM
