Results 1 to 3 of 3
    Salil's Avatar
    Posts
    Global Posts
    76 Global Posts
    Default Desperately need your help on this issue
    Hey,
    Have been asking this forever and I really need help for I have tried everything. My Droid Charge just spikes up in CPU usage to 100% and stays there forever never coming down. This usually happens when I am driving and using my GPS and also my bluetooth is connected to the car fm modulator. During this point of time I can't go into any other app to check which app is taking up the cpu cycles and kill it. My only option is to reboot. Can someone please let me know:
    1. Is there any app that records cpu usage so that I can diagnose as to what is causing this problem. I don't need an app that tells me which app is using CPU at this point of time since I won't be able to run this app since my phone just freezes. So I need an app that records cpu usage rather that reports it right now.
    2. If the above is not possible is there an app that can be used to kill the app that is taking up maximum cpu and something that can be triggered using a hardware switch(like a power button).
    3. Will changing the kernel etc. help at all. Right now I am running 2.6.35.7-FP1. Can I flash a kernel without having reload all my apps and data?
  2. Thread Author  Thread Author    #2
    Salil's Avatar
    Posts
    Global Posts
    76 Global Posts
    Default Re: Desperately need your help on this issue
    I have been partially able to fix the problem. One I downloaded Copilot Live as a navigation app which uses offline maps instead of downloading maps on the fly like google nav. However, still my phone used to lag close to 20-30 seconds when I would go to my home screen and similarly when I went to my application lists. I was using Seepu so I could see that my CPU was at 100% all the time. This led me to believe that there might be an issue with my SDCard and hence I downloaded sdbooster .
    I saw an amazing performance improvement after I set the cache size to 8192 mb and the lags all but disappeared. However, still when I am on my home screen it sometimes lags 5 seconds which is still infuriating. What the heck is it doing, is it reading apps from the disk?
  3. #3
    mesocyclonic's Avatar
    Posts
    ROM
    Stock
    Quote Originally Posted by salilsurendran View Post
    Is the lag you notice beyond what you see with other apps? I've noticed 5 second lags on occasion with my Charge doing things completely unrelated to mapping with GPS/Bluetooth off.
