1. feltron3030's Avatar
    I bought a phone on Craigslist and it was already rooted but the major problem is my phone will not receive incoming calls, does not ring but calls show up in call log. Voicemail works fine, is this because the phone is rooted or something else?
    08-26-2012 07:57 PM
  2. Chocoburger's Avatar
    Have you done a factory reset? If it doesn't work, are you willing to flash to stock software onto the phone? You can't send it to Verizon or show it off in store if it is rooted, they won't like that. You'll want to flash back to stock via Odin first, which may fix your phone in the process, but if it doesn't Verizon may then be able to assist.
    08-27-2012 12:38 PM
  3. feltron3030's Avatar
    Tried the factory reset and still same problem, if I flash to Odin what are the chances that my phone will turn into a brick?
    08-30-2012 02:09 PM
  4. Chocoburger's Avatar
    Flashing with Odin should be safe as long as you're using a good file properly. Droid Charge with Odin must always be used with "PDA" and never with "PHONE". If you flash it under phone, it will be bricked.
    Whichever set of instructions you choose to follow, make sure to read it a couple of times through in order so you're prepared. Other than that you should be fine.
    08-30-2012 06:17 PM
  5. papa54's Avatar
    be sure when you get ready to start odin to send info yo your phone, stick the battery back in the phone.. seems the Charge loves having the battery iin when doing an odin operation.. if you dont you will always get a "Failed" msg
    09-03-2012 09:15 PM
