Results 1 to 4 of 4
- 09-11-2012, 10:38 AM
Thread Author #1
Need help loading music via PC
I'm trying to load music using the Sync tab on Windows Media Player, but I can't get it to recognize the device.
I tried the "Media Sync" option and the "Mass Storage" option when I plugged it in via USB and neither seem to work.
I'm sure it's something simple I am overlooking, but after 30 minutes of trying I realized it might just be easier to ask. Any suggestions?
Thanks! - 09-13-2012, 07:56 PM #2
Re: Need help loading music via PC
I would suggest you cut out the software and go right for the files. Trying to make Windows Media Player talk to Android is quite a challenge. If you get that to work, please share.
Okay, now how to fix the issue... go right to the music files on your PC. You can get fancy and use an app like Double Twist which is free for wired or paid for wifi sync. But I like it the old way... I pull out my micro SD card. Slide it into an SD Card adapter to make it full size and plug it right into the computer. I like taking the phone and computer software out of the picture. I then just drag over all the music, movies, etc... that I want.
Davewww.youtube.com/kraisydave
www.KDtech.org Twitter @kraisydave
Everyone deserves to get the most out of their phone! - 09-14-2012, 03:53 PM
Thread Author #3
Thanks - sounds like I need an adapter then. For the life of me I just can't get it to connect at all wired. So weird. It used to work. Even tried installing a driver update, various settings, different cables, different USB ports.
I'll pick up an adapter and give it a shot. Sounds like it'll work. Thanks again! - 09-22-2012, 02:45 PM #4
Glad to help. Amazon.com: SanDisk microSDHC 8GB Class 2 Card with SD Adapter (SDSDQ-8192): Computers & Accessories
Let me know how it goes...www.youtube.com/kraisydave
S3 need help with connecting to PC and Go SMS pro
By boflexx in forum T-Mobile Galaxy S3Replies: 1Last Post: 08-03-2012, 08:53 PM -
Need Help Syncing Contacts via Bluetooth to car
By martin82531 in forum Motorola Droid 4Replies: 1Last Post: 04-30-2012, 11:03 PM -
Need Help Adding Music
By Apostolos in forum LG Optimus SReplies: 2Last Post: 11-19-2010, 02:10 PM -
Google Maps loading problem with GPS-Need help.
By arcane#ac in forum HTC HeroReplies: 0Last Post: 12-13-2009, 05:18 PM -
Need to Load back Default Android - Please Help
By raghurajang in forum T-Mobile myTouch 3GReplies: 2Last Post: 12-09-2009, 02:51 PM
Reply
