02-23-2017 03:02 AM
187 12345 ...
tools
  1. Shahram Iranipour's Avatar
    Thanks a million:d
    08-21-2013 06:35 AM
  2. Somdk's Avatar
    Thanks a million:d
    Your welcome....
    What exactly had happened to your Sd card ? What brand was it ? The capacity of it ? And how did you resolve it ?
    Sent using AC Forums mobile app
    08-21-2013 07:14 AM
  3. wicc's Avatar
    I don't know how to thank you enough -- I was using my phone, turned it off and then back on. When it finished booting, the micro sd would not load up and my GS3 was telling me that the card was corrupt and telling me to format it. It would not mount or anything. When I put the micro sd into a usb reader, it was doing the same thing. My cpu was telling me it was corrupt and needed formatting. When I checked the properties, it showed the card was empty.
    When I followed your very easy steps to repair. Less than 10 seconds later (literally) it was working again....Not a single file was missing....
    I am so glad that I came across your post. You saved my life, my phone, my sanity and most importantly the sd card. I can't thank you enough for your post.
    -- THANK YOU -- THANK YOU -- THANK YOU --
    Very Much Appreciated, wicc
    08-22-2013 12:53 AM
  4. wicc's Avatar
    I think I Got it Finally.
    Recovering Data is not the solution Not even Formatting your SD card.
    I have the same problem after some days it doesn't load some Apps in Android when i check it in the settings it shows "DAMAGED SD CARD"
    I tried to connect with SD CARD Adapter slot in my Laptop but still couldn't detect and it asked to Format it.
    I tried to fix it with "CHKDSK" utility but couldn't do it through windows.
    But could do it with command prompt.
    Not if you have the same problem follow.....
    connect your SD card to computer.
    open command prompt.
    How ? .......
    open run from start button
    then type "cmd"
    now type
    chkdsk /X /F <SD card drive letter>:
    If its K drive then
    chkdsk /X /F K:
    It will check your card and will repair it.
    Have patience it will take around 10 min.
    when it is done windows will detect your card evn your android phone.
    Have a nice day......
    08-22-2013 12:56 AM
  5. Somdk's Avatar
    For everyone's information can you please tell what did you provide when the end of the chkdsk you are asked for Y or N ?
    Ps-that will give this thread a permanent solution....
    Please do share.....
    08-22-2013 01:04 AM
  6. arooj miran's Avatar
    my sd card isnt mounting...!!
    a massage is coimg " damage sd card"
    dude help me out...i have my bundle of pics in it...and i havent saved any where else
    08-23-2013 01:00 PM
  7. arooj miran's Avatar
    i have a lil problem
    its saying "can not open for direct access..what should i do now?
    08-23-2013 01:31 PM
  8. Somdk's Avatar
    Did you read all the prelim checks mentioned in this thread ?
    08-23-2013 01:50 PM
  9. Somdk's Avatar
    firstly,
    Check if you are inserting the sd card properly. Listen for the click when it correctly enters its slot.
    Do not transfer any thing new to the sd card now.
    Did you try reading it through another mobile drvice ?
    Did you try to read it using a mirco sd card reader ? What is it showing on the pc ?
    Please mention the details.
    Also mention the basic info your sd card and thr device on which you were using this card.
    08-23-2013 02:12 PM
  10. arooj miran's Avatar
    i dont know why my comp is sayin " volume can not be accessed directly.."
    help me out with this
    08-24-2013 02:17 AM
  11. Somdk's Avatar
    Read all the posts and did you try any of the solutions mentioned here in this thread ?
    08-24-2013 05:45 AM
  12. Somdk's Avatar
    Try Recuva
    08-24-2013 06:32 AM
  13. Somdk's Avatar
    What sort of files did you have on the sd card ?
    As a usb drive or a mobile storage drive (the icon of which looks different).
    When you right click on the drive representing the sd card, what options are shown ? Is the option to format is there ?
    No matter what solution you find and apply, please read the pros and con well before well.
    08-24-2013 07:33 AM
  14. iMantisNZ's Avatar
    I ended up having a very simple fix.
    I'm running OS X and I used an adaptor to plug in my microSD card to my laptop.
    1. When I first opened Disk Utility (in Applications>Utilities), the SD card showed up but the "NO NAME" partition was grayed out.
    2. So, I selected the SD card and ejected it, then pulled it out and reinserted it into the reader.
    3. This time, the "NO NAME" partition was black. I held my breath and clicked the Repair Disk button and, voila, my Samsung GS3 displayed all my pictures and videos once more (after putting it back in my phone - don't forget to eject!)
    I turned on WiFi sync on Dropbox again.
    Thank you so much! I was panicking that I'd lost all my photos etc. But this worked a charm!
    My Samsung Galaxy Ace came up with a message just after I'd finished transferring music to it that the SD Card was damaged. I tried the card in my old Nokia C3-00, and it still didn't work. I reluctantly decided to format the card, however it wouldn't format. After trying the command prompt-theory which results in it spitting out that it CHKDSK isn't available for RAW drives, I tried your theory. I plugged my phone into my computer via USB cable, and it asked to format the SD Card. I checked in My Computer and noticed a new drive that had the same letter as my SD Card previously named "Removable Disk (H. I ejected it, disconnected the USB via the phone, and removed the SD Card and reinserted it. Straight away, it recognized it and all of my files came back.
    If the first method doesn't work, definitely try this one! (y)
    08-26-2013 03:58 AM
  15. Andi Bowden's Avatar
    I dropped my phone earlier at work & My sd card wont work & keeps saying " mount sd card' I have done all I know to do, and I have LOST ALL MY PICTURES! cant take pics or upload pic on apps ect. help me please?
    thanks,
    andi
    08-30-2013 01:18 AM
  16. Somdk's Avatar
    Did you try to insert the sd card into some other micro sd card reader and checking off the sd card is accessible or not ?
    08-30-2013 03:06 AM
  17. Neeraj Soni's Avatar
    I salute you dear brother..........
    Keep it up
    08-31-2013 12:16 AM
  18. Somdk's Avatar
    Keep it up
    Please be kind enough to share your experience and solution that worked for you...
    08-31-2013 12:26 AM
  19. ilovekiki92's Avatar
    hey my sd card slot holder wont keep my card in the slot it keeps popping out and it will not read my card? please help
    08-31-2013 06:31 PM
  20. Somdk's Avatar
    Have carefully tried to insert the card in the slot ? Slowly and carefully push it in till you hear a click. Dont try too hard as that might injure the sd card. If it continues not fit in, take it to a nearby store.
    08-31-2013 10:57 PM
  21. cossak2007's Avatar
    Used above suggestions without a solution.
    Could not read files on sd disk with phone or Windows 7
    File system was corrupted so I used chkdsk <drive> with /R along with the /F option.
    This fixes bad sectors and repairs disk.
    Saved me from formatting the sd card.
    Somdk likes this.
    09-01-2013 10:28 AM
  22. Somdk's Avatar
    I too had this problem but as I didn't know DOS much did not use chkdsk. Found another way to get back my pictures. Can you share a particular point in your way of solving this problem ?
    09-01-2013 11:30 AM
  23. cornyflakes's Avatar
    I too would like to know about this little Y/N detail. anyone?
    Amjad Nawaz likes this.
    09-03-2013 02:22 PM
  24. Amjad Nawaz's Avatar
    Hi,
    Sr,
    How are you ?
    I am Amjad Can you help me please repair the my Tablet Android error the Damaged sd card and no accept usb stick for conacted the inter net .
    Thank you with Regard
    - - - Updated - - -
    Hi,
    Sr,
    How are you ?
    09-07-2013 07:41 PM
  25. Somdk's Avatar
    Hi,
    Sr,
    How are you ?
    - - - Updated - - -
    Hi,
    Sr,
    How are you ?
    Hello
    What do you mean by "no accept usb stick for contacted the internet" ?
    Android Central App....Rocks!!
    09-07-2013 10:03 PM
187 12345 ...
  1. Replies: 55
    Last Post: 08-31-2016, 03:51 PM
  2. SD card damged on mount with apps2sd
    By redbeardtheweird in forum HTC Hero
    Last Post: 10-11-2014, 04:47 AM
  3. Damaged SD card error?
    By bbasiaga in forum Barnes & Noble Nook Color
    Last Post: 09-01-2013, 12:41 AM
  4. HELP! "Damaged External SD card" Error
    By tarichar in forum Verizon Fascinate
    Last Post: 06-01-2011, 02:27 PM
  5. G1, sd cards, and pc mounting
    By hououtate in forum T-Mobile G1
    Last Post: 09-28-2009, 03:12 AM
