Page 6 of 6 FirstFirst ... 3456
Results 126 to 148 of 148
Like Tree16Likes
  1. #126
    Default Re: Droid Charge: Damaged SD card Error / Won't Mount - Fix??
    I have the same issue as Chen Meiying and I'm frustrated cause my 32GB SDHC cost me much money
  2. #127
    Same problem as some others here:
    The type of the file system is RAW.
    CHKDSK is not available for RAW drives.
  3. #128
    This did not work for me...
  4. #129
    How did you fix it my sd card is doing the same thing yours is and I need it to store all my photos on it that I have of my daughter and everything else I have a lot of my music on the sd card as well
  5. #130
    Default Re: Damaged Sd card Error / Wont Mount - Fix??
    MY laptop can read the SD card but my Galaxy S3 is saying the SD card is either blank or has unsupported files on what should I do
  6. #131
    PUNISSHER's Avatar
    Posts
    Global Posts
    50 Global Posts
    I did the "chkdsk /X /F <SD card drive letter>: in cmd" a few weeks ago and it worked flawlessly. This time around when I tried it, i got "Cannot opem volume for direct acess"
    Anyone have a new fix or an explanation behind this error message??
    Thanks in advance
  7. #132
    I know this is a old thread but I need help my memory card is not working it says mount sd card but its in already. .I have lost all pics vids and music it also wont recognise it in my camera or galaxy tab.not even a notification to say i have inserted a memory card I have a Samsung galaxy s3 mini any help is greatly appreciated it has the birth of my baby and first xmas etc :-( really badly want them back. I don't want to format it as need pics of off it.i currently dont have a pc so havent tried the instructions put up im not in any way a computer boffin so wouldnt know how to anyway
  8. #133
    If laptop is recognising it I don't see the problem? Just copy all the pics on top laptop..?
  9. #134
    Exclamation Re: Droid Charge: Damaged SD card Error / Won't Mount - Fix??
    guys please help me out,
    my newly bought transcend micro sd (8gb) isn't mounting on my android phone (samsung galaxy s3 mini)
    -it always says "damaged sd card" and when i insert it in my computer, it always says that "the disk in drive d: is not formatted, format it now?"
    -but when i format it, it always says that "windows is not able to complete the format."
    -when i use the "chkdsk" on "command prompt." it says that "the type of the file system is RAW. CHKDSK is not available for raw drives.
    please help me out =(
    i lost my every precious files and softwares...=(( PLEASE HELP
  10. #135
    when i tried the command prompt all it said was "cannot open volume for direct access."
  11. #136
    guyz i already finish @ cmd after that i insert it in my cp but theres a noti. damage SD CARD IS DAMAGE...... plz help.... T.Y.
  12. #137
    I have a 32gb sandisk microsd card and I can't copy anything to it. After copying no files will show in the card and the space is free in the card. And when I remove the card and reinsert in my SGS4, It says it is damaged. Somerimes it is working. Please give me a solution to this. .
  13. #138
    Quote Originally Posted by wicc View Post
    I don't know how to thank you enough -- I was using my phone, turned it off and then back on. When it finished booting, the micro sd would not load up and my GS3 was telling me that the card was corrupt and telling me to format it. It would not mount or anything. When I put the micro sd into a usb reader, it was doing the same thing. My cpu was telling me it was corrupt and needed formatting. When I checked the properties, it showed the card was empty.
    When I followed your very easy steps to repair. Less than 10 seconds later (literally) it was working again....Not a single file was missing....
    I am so glad that I came across your post. You saved my life, my phone, my sanity and most importantly the sd card. I can't thank you enough for your post.
    -- THANK YOU -- THANK YOU -- THANK YOU --
    Very Much Appreciated, wicc
  14. #139
    my pc is also saying to format it.
    it says that cannot open volume for direct acess
  15. #140
    New here but have been sharing your pain with the whole "damaged SD card" thing.
    I've had this a couple of times on my Galaxy Ace and the last time it happened I used the chkdsk/x/f trick and it worked a treat.
    However, yesterday I was playing some music through the phone but I found that you cant stop the music, only pause it so I did a full phone switch off. That certainly stopped Fleetwood Mac but also appears to have wrecked the micro sd card as well - the dreaded "damaged SD card" reappeared.
    I wasn't too concerned as I thought the chkdsk thing would work but IT DIDN'T!
    The thing is that the when I put the micro sd into the sd card reader and hooked it up to my pc (running XP) the card was fine - everything was readable so the chkdsk command had nothing to put right.
    In File Manager I ran Properties and did the whole scan disk routine, I even scanned the card with AVG. Nothing would induce the phone to mount the card. I put it in my Samsung Tab 2 - same fault appeared, back in the pc - working fine.
    So I ran the Backup utility in File Manager and created a copy of everything on the card and saved it to my pc hard drive, and then copied the backup onto another micro sd card and mounted that in the phone. Everything worked fine - the photos were there, Whatsapp messages reappeared, camera worked. Result.
    Next I reformatted the original sd card in the phone (ie wiped it clean - do NOT do this until you have checked and confirmed you have a workable backup copy elsewhere) then safely removed the card, loaded it back into the pc, copied the backup from the pc to the sd card, remounted that version - and again everything worked!
    I have absolutely no idea what the fault was as the card worked on the pc but not in any android device. The only fix was to reformat and start again.
  16. #141
    EA82's Avatar
    Posts
    Why is everyone skipping over the RAW questions?! I just want to save my files! please help us!!
  17. #142
    hey mukund
    having same problem with my 32 gb sd card
    and while trying your solution
    DOS window says: access denied as you do not have sufficient privileges. you have to invoke this utility running in elevated mode.
    i am not an IT professional, so didn't know what to do next.
    please help
  18. #143
    Droid Charge: Damaged SD card Error / Won't Mount - Fix??-untitled.png it didnt help me this is what appears please help
    Attached Thumbnails Attached Thumbnails Droid Charge: Damaged SD card Error / Won't Mount - Fix??-untitled.png
  19. #144
    I am having this same problem and I am very tempted to format my SD card and the only reason I am is because I have download an app called Dropbox and mind you that it connects to my computer, tablet and phone and I suggest that anyone if in future face this problem to download this app and connect with your computer. It will backup all photo's and any files that you feel that you need to save. You can even create files to backup just your music.
    https://www.dropbox.com/
    I am just saying this saved me big time. Although I am disappointed that I have to add everything back in. Apps are recoverable since you can download them back from google play but music and photos/files are hard to recover. This saved me a lot time too! I suggest that everyone download this and the more gadgets you add the more space you are given to save in dropbox for about a year but it will be more than enough.
    I hope this helps somehow! At least if this happens in the future you have everything backed up. Also there is another function in newer android phone,Samsumg galaxy s3, s4, and s5 that can back up files for you as well. I am not to sure what it is called at the moment but I will check it out on my s3 and let everybody know.
  20. #145
    Old thread, but for anyone else searching as I was for several days, my fix was cleaning the contacts on the card with alcohol and a Qtip, letting it dry, blowing out the port on the phone with compressed air (hubby used the tank for airing up tires as I was out of canned compress air. Then, cleaning internal contacts with alcohol, letting dry. Worked immediately!
  21. #146
    does anyone knows how to fix the damage sd card. i tried to run the dskcheck, but it says it is a raw file..what should i do?
  22. #147
    Yo mukundrathod111 , followed your instructions to the tee and it worked perfectly. Thanks man. Saved me time, headaches, and money.
  23. #148
    Made an account to say thank you. I had a tonne of work pics as well as music, vids, etc. Used chkdsk for a total recovery from an unreadable/corrupted MicroSD card in my Samsung Galaxy S3 Mini.
    Cheers Dude!
  1. Damaged SD card error?
    By bbasiaga in forum Barnes & Noble Nook Color
    Last Post: 09-01-2013, 12:41 AM
  2. Replies: 53
    Last Post: 06-18-2013, 01:21 PM
  3. HELP! "Damaged External SD card" Error
    By tarichar in forum Verizon Fascinate
    Last Post: 06-01-2011, 02:27 PM
  4. SD card damged on mount with apps2sd
    By redbeardtheweird in forum HTC Hero
    Last Post: 11-13-2009, 07:51 AM
  5. G1, sd cards, and pc mounting
    By hououtate in forum T-Mobile G1
    Last Post: 09-28-2009, 03:12 AM
