Page 7 of 7 FirstFirst ... 4567
Results 151 to 153 of 153
Like Tree18Likes
  1. #151
    Default Re: Droid Charge: Damaged SD card Error / Won't Mount - Fix??
    Hi All:
    My 16GB SD Card works fine in my PC but not in my Micromax phone..
    I tried the chkdsk option given here but I am getting this message.... after running till 71%......
    C:\Documents and Settings\Krishna>chkdsk /X /F I:
    The type of the file system is FAT32.
    Volume Serial Number is 9016-4EF8
    Windows is verifying files and folders...
    The size of the \mtklog\aee_exp\db.03\db.03.dbg entry is not valid.
    What should I do? Please help....
  2. #152
    won't turn on completely
  3. #153
    Hi. i had a similar problem and found a solution. i have an htc thunderbolt, and randomly the sd card became damaged it was appearing as not there, or occasionally it would work for as few minutes. luckily i could still access the files on my win 8 pc, so i saved the important stuff. i tried a reset, and that didn't work. so i did what i dreaded to do. i opened settings in my phone and tapped erase SD card. the files are gone, but now my phone can read my sd card. probably on too many drops so yeah, now to recopy over my music. ps, if music copying is a pain for anyone, if you only have a few songs to send over, send yourself an email with the songs attached. i found that to be far preferable than trying to deal with HTC drivers in my win 8 pc.
  1. SD card damged on mount with apps2sd
    By redbeardtheweird in forum HTC Hero
    Last Post: 10-11-2014, 05:47 AM
  2. Damaged SD card error?
    By bbasiaga in forum Barnes & Noble Nook Color
    Last Post: 09-01-2013, 01:41 AM
  3. Replies: 53
    Last Post: 06-18-2013, 02:21 PM
  4. HELP! "Damaged External SD card" Error
    By tarichar in forum Verizon Fascinate
    Last Post: 06-01-2011, 03:27 PM
  5. G1, sd cards, and pc mounting
    By hououtate in forum T-Mobile G1
    Last Post: 09-28-2009, 04:12 AM
